A symmetrical figure, rotated by an unknown angle. How to adjust the angle to normal level? Or how to measure the angle of two anchor points?
@monsterfox , my strategy is to draw a rectangle between the two reference points, then do arctan(height/width) and you have the angle to apply.
At some point we may be able to type in math expressions in fields and have VS parsing them...BR/ Lars
@larsherold said in A symmetrical figure, rotated by an unknown angle. How to adjust the angle to normal level? Or how to measure the angle of two anchor points?:
This is already possible, and (depending on the field) it is also possible to set number properties as expressions using number variables defined at document level.
@VectorStyler said in A symmetrical figure, rotated by an unknown angle. How to adjust the angle to normal level? Or how to measure the angle of two anchor points?:
Ah great! I'll dig into that..
@VectorStyler The new feature is great, the experience is very special, I never thought it could be achieved in this way to rotate the angle, your thinking is very active. There are two details, I hope to be strengthened. 1. This new feature supports single paths and merged paths, but not groups, I don't know if it can be achieved? 2. When rotating, it is rotated around the first plotting point, can it be achieved to rotate around the object itself?
@monsterfox said in A symmetrical figure, rotated by an unknown angle. How to adjust the angle to normal level? Or how to measure the angle of two anchor points?:
I added these to the backlog.
@VectorStyler I suddenly thought of a more convenient way to work today. After selecting points A and B, set the angle in the path panel. Can a mouse wheel shortcut be added, and slide at angles such as 90 degrees and 180 degrees, which will have a more convenient operation experience.Can this function be added, thank you for your hard work.
@monsterfox I will try to find a way to make this easier.
This post is deleted! -
@VectorStyler This feature still does not support groups. Can you add it first? Thank you. I've been waiting for a long time.
@monsterfox I have this in the feature backlog for 1.3, I will tyr to bring it forward.
