    A small detail - Removing an unfound file from the list
    11 Posts 5 Posters 9.4k Views 4 Watching
      VectorStyler @B-Vs-V
      @Pat Added to the backlog.
        monsterfox @VectorStyler
        @VectorStyler Such a dialog box. The Tab key is not working. Can it be added?
          VectorStyler @monsterfox
          @monsterfox said in A small detail - Removing an unfound file from the list:
          Will do so.
            The fact that the file is not found here and now does not necessarily mean it no longer exists. It could be that an external SSD, a USB drive, or a network drive has not been connected, which often happens in various situations on a company laptop that is on and off the network.
            All frequent scenarios for my usage and work situation.
            • B Offline
              B-Vs-V
              VS won't let you find the file via this dialogue box anyway.
                Ingolf @B-Vs-V
                @Pat said in A small detail - Removing an unfound file from the list:
                Not until I reconnect the drive - which I do. And then I need VS to remember the file and its path, thank you very much.
                  Boldline @Ingolf
                  @Ingolf said in A small detail - Removing an unfound file from the list:
                  I agree with this and would keep it in the list. maybe if an asterisk was added in the list to signify to was a missing file?
                  • B Offline
                    B-Vs-V @Boldline
                    @Boldline In that case, it's certainly better to keep the name in the list. As my PCs have internal hds several terabytes in size, I don't use external hard drives (except as backups).
                    • B Offline
                      B-Vs-V @VectorStyler
                      @VectorStyler I don't know if it's possible but it would be useful to see the location of the file by leaving the mouse pointer over the name of that list ☺
                        @B-Vs-V said in A small detail - Removing an unfound file from the list:
                        Not in the menu. The only option is to list files with complete folder name.
                        But it can show in the alert view.
