    Could the offset path panel be unlocked to be able to move around the screen?
    6 Posts 4 Posters 6.0k Views 3 Watching
      Could the offset path panel be unlocked to be able to move around the screen while in use?
      Right now, when I open the Offset Path panel, it appears on the screen and I have to adjust the shapes below to be out of the way of the panel itself. I'd love to be able to drag the panel to the side while it's in use
      0_1725403372162_119bcfd3-3e3a-46ed-b56f-c6e3bca57fe4-BLD 2024-09-03 at 18.41.48.png
      M S VectorStylerV 3 Replies Last reply Reply Quote 1
      • M Online
        monsterfox @Boldline
        @Boldline Ctrl + Mouse Wheel, the screen moves up and down. Ctrl + Shift + Mouse Wheel, the screen moves left and right.
          Subpath @Boldline
          How about using the "Shape Effect Panel" ?
          This is movable
          Panels > Effects > Shape Effects
          then select the "Offset Path Effect"
          Outline > Offset Path
          here a video
            @Boldline It can be moved around the screen, but the document cannot be accessed in the background.
            I think what is needed here is that this view should behave like a panel.
            I will add this to the backlog, but only for 1.3 (would be a bit different feature).
            The non-destructive offset path effect can be added and adjusted from the Shape Effect panel, but that is a bit different.
              @VectorStyler said in Could the offset path panel be unlocked to be able to move around the screen?:
              Yes, this is what I was hoping for with the Offset Path panel; that it can be moved around so the selection on the artboard can be seen without having to wonder where the offset path panel will show up and potentially obscure the selection below.
              I understand that the selection itself would not be accessible.
              thanks for adding it to the list!
                @Boldline There seems to be a regression here. The problem was identified and the fix will be in the next build.
