    Regarding the halftone repeater types
    76 Posts 6 Posters 204.7k Views 4 Watching
    • L Offline
      Li Xiao @VectorStyler
      String Art generates fascinating designs, and there are also some free online tools available to create them.
      https://www.youtube.com/watch?v=dBlSmg5T13M
      The two online generators I often use support SVG output.
      https://piellardj.github.io/image-stylization-threading/
      https://akashsarker.com/string-art-generator/
      0_1718437828474_String Art.jpg !
      Btw, when opening SVG files with VectorStyler, transparency is lost.
      0_1718437842169_String Art.svg
        VectorStyler @Li Xiao
        @Li-Xiao These are for further down the road.
        The opened a bug on the svg import issue.
          @Li-Xiao I could not download the svg file, it seems to be a binary file
          S L 3 Replies Last reply Reply Quote 0
            Subpath @VectorStyler
            @VectorStyler said in Regarding the halftone repeater types:
            i tried it also and get only a bitmap
            seems a wrong file extension
            • L Offline
              It seems like uploading it again didn't make a difference.
              The zip file should be fine now.
              0_1718440087305_String Art.zip
                Subpath @Li Xiao
                @Li-Xiao , is ok now
                • L Offline
                  The Repeater is missing a fundamental feature: keep the original arrangement of all objects or text.
                  Lately, I've been needing this frequently, but I can't find any method in Repeater; I have to resort to using other software.
                    @Li-Xiao This would not be a repeater feature anymore, but something else. I have a new feature planned for the next version, that is a "live" adjustment to a group of objects, using the adjustment tools of the repeater.
                    • L Offline
                      @VectorStyler Thank you so much, looking forward to it!
                      Btw, in the recent versions, adjusting number values for Blended shape in the Repeater does not work.
                        @Li-Xiao said in Regarding the halftone repeater types:
                        I will try to find out what can cause this.
                          I cannot replicate this. Can you send me a file where the number value is not adjusted? Thanks!
                          • L Offline
                            @VectorStyler Sorry, I've been a bit busy lately. I didn't explain clearly. I meant multiple blended shapes, not a single blended shape. I couldn't find the files I make on before. I'll redo them when I have some time and send them to you.
