    Option to select all nodes on a path with one click by also pressing alt/option modifier
    6 Posts 5 Posters 6.1k Views 3 Watching
      I saw this Illustrator trick on Instagram today and it seemed like a useful thing.
      If you hold down the alt/option key while clicking on a node of a path, the entire path will be selected. I know available modifier keys are scarce these days, but it could be a neat option with any modifier
      0_1720535106172_96b3c425-6a8f-4d42-b052-2b572d718cf8-BLD 2024-07-09 at 10.19.02@2x.png
        @Boldline I added this to the features backlog.
        • W Online
          William Kansepa
          @Boldline that's one of my favourite features in Illustrator!
          Just wanted to say in VS you can achieve the same: click on a node and press Control +A... oops that's 1 or 2 extra moves. But it works.
          M 1 Reply Last reply Reply Quote 4
            monsterfox @William Kansepa
            @William-Kansepa Compare curious why you select all nodes mainly for what operation to do preparation? I also often select all nodes, mainly using node optimization tools.
              VectorStyler @monsterfox
              @monsterfox said in Option to select all nodes on a path with one click by also pressing alt/option modifier:
              The primary feature here is to select all nodes of a sub-path (a section of a combined path) to move around or transform
                Apart from that i find it useful to select all Nodes of a Shape this way
                i find it also helpful for to add new Nodes the Corel Way
                Select a node, then press CTRL+A to select all nodes
                and then press "+" as many times as you need and
                you have evenly inserted Nodes all around the Shape
                Here a little Video
