update 1.2.031
VectorStyler 1.2.031 release notes
- Shape picker tool to position shapes correctly.
- Show correct font style names for Type 1 fonts.
- Improved support for large image sizes.
- Keep locked and invisible objects with artboards, also handle undo correctly for this.
- Arrange artboards should also work with locked objects.
- Register as spot color should also work for colors without names.
- Drag and drop colors from custom to main palette.
- Improved Navigator view preset handling.
- Option to show starting and ending nodes using regular node styles.
- Setting indicator sizes for transform selection.
- Update export size in export view.
- Layers panel menu option to move objects to highlighted item.
- Do not add an artboard to the top canvas category by default.
- Do not change artboard size when changing other document options.
- Duplicating artboards to place copied objects in their current layer.
- Added a HSL color mode (replacing HLS).
- Update guideline coordinate in transform panel after changing.
- Shift+Click should deselect single objects.
- Exporting images should not add extra width or height.
- Fixed the horizontal transform panel content.
- Fixed the opacity handling of the Inner Shadow effect.
- Fixed the image effect handling when blending objects.
- Expand symbols when working with the trim and join tool.
- Added the "Transformed Fill" (and Content) option to the transform panel menu.
- Show font style list with other font category is active than the selected font.
- Added automatic number to preset names when creating presets.
- Allow selecting color style in the color scheme editor.
- List color scheme styles in the fill popover.
- Fixed the undo after applying shape effects styles.
- Improved color variations.
- Show brush size changes in eraser and path brush tools.
- Improved "Transform Each" mode for copying objects.
- Fixed a navigator panel docking error.
- Pixel preview to use the resolution set for the document.
- Improved handling of math expressions when units are present.
- Improved font list preview sizes.
- Transparency panel should update blend mode also when editing gradients.
- Fixed a contour profile selection error.
- Appearance panel to work with larger number of objects.
You've heard it many times and it certainly won't be the last.
But I wanted to express my appreciation once againI'd like to say again how impressed I am by your enormous workload.
Other companies would need 10 or more updates for something you do in one.A deep bow from me and a big thank you.
Almost a Same Day Delivery Service of bug fixes and new features. Unprecedented!
Still a few questions about v.031.Added the "Transformed Fill" (and Content) option to the transform panel menu.
I can not find it...
I post Distribute and organize objects between layers and sub-layers: you announced:
Meanwhile, an other approach is already implemented (for the next build) that adds minimal changes to existing functionality. Let's see how this will work out first.
I can't find this either or am I overlooking something?
Nevertheless, you will also receive a deep bow and a big thank you from me, quoting Subpath's striking words.
@Ayo said in update 1.2.031:
"Transformed Fill"
This is visible only when an object with fill is selected.
About organizing layers: there are two features (one already existed with a minor bug).
The first (new) feature is the "Place Before/After/Inside" commands from the Layers panel menu.
- assuming that the on canvas and Layers panel selection are not synchronized (here is the advantage)
- select some objects on the canvas (with the regular selection tools).
- scroll to and highlight an object in the Layers panel (this will have the strong blue highlight).
- then the "Place Before/After/Inside" commands of the Layers panel menu will place the selection on the canvas before/after/inside the highlighted object.
The other (existing) feature is using multiple Layers panels. In the Layers panel menu use the "Open New Panel" command to open another layers panel. Now you can position each list differently and use drag & drop to move or copy objects between the panels.
There are also the "Open with..." layer panel opening modes that will fix the opened panel content to the current document (or location) and can be used to copy objects into (or from) an other document.
@VectorStyler said in update 1.2.031:
then the "Place Before/After/Inside" commands of the Layers panel menu will place the selection on the canvas before/after/inside the highlighted object.@VectorStyler, thank you for elaborating. However, this new method will not work if you have 'Select Highlighted' active. Tough for me since I like using 'Select Highlighted'. This setting is critical in my workflow.
@William-Kansepa said in update 1.2.031:
That is true, this needs the separate selection mode.
But maybe then using two Layers panels might help.
