    Start Node - disable it from hiding the real type of node
    18 Posts 7 Posters 16.7k Views 5 Watching
      Boldline @Ayo
      @Ayo @Ingolf I think it serves more than just 1% to show the starting node differently. I'd leave it on by default but offer an option in settings to turn it off or allow for it to be adjusted if the user prefers with a color, etc.
      I think VS needs to be set to "easy to learn as possible" by default and allow power users to make the adjustments they prefer in the settings and save those custom settings. New users are not necessarily scanning their nodes
        VectorStyler @Ingolf
        @Ingolf said in Start Node - disable it from hiding the real type of node:
        I propose/prefer a more discreet indication of the start node, perhaps just attributes like color (stroke, fill), and the option to disable this indication altogether in the user interface.
        I find a way to do this. But it will be an option to select.
          Much appreciated 🙂
          • L Offline
            Li Xiao @Ingolf
            @Ingolf In my work, the start node is crucial. Changing the start node in CorelDraw is quite cumbersome as it requires disconnecting and reconnecting a node. Therefore, I spent money to customize a feature related to the start node. VectorStyler is much more convenient. Just select the node and press "s" to get it done. It would be necessary to have an option to cater to different user needs, allowing users to make choices based on their requirements.
              While I'm thinking of it, start nodes matter often when designing. They also matter when it comes to blending objects together
              • AyoA Offline
                Ayo
                @Ingolf
                Sometimes, for some users, certainly not indispensable. Remember that the triangle symbol besides start or also symbolizes the direction of the path. Sometimes useful for even/odd fills, winding rules, text on path and maybe more.
                  Ingolf @Ayo
                  @Ayo Yes, but I have never needed it over several decades. In my use cases, having it visible is a burden. I've created billions of complex illustrations, but this particular feature has never been relevant to me. I can't be the only one nor a minority.
                  I think we should take a broad look at the customer segment today, that vector illustration programs have become commonplace, and that there are many quite ordinary illustrators out there for whom many classic features in vector programs are not daily relevant. Furthermore, in my experience, they are less likely to frequent forums. For example, in Serif's forums, you won't find many regulars who don't happen to know programming languages like JavaScript or even more advanced. I find it hard to believe all Affinity customers both create art and code.
                  An option would be fine. No option, a pain. 🙂
                  • debraspicherD Offline
                    debraspicher
                    I like having it, but yes sometimes it gets in the way visually.
                    32GB RAM @ 6000MHz
                      fde101 Global Moderator
                      Personally I think it would be best to find some way to keep it on, but as an indicator on top of the "normal" indicator - put a differently-colored dot in the middle of it or just make the outline thicker or something - visible enough to stand out, but not block the normal interpretation.
                      The end point probably doesn't need to be specially marked as long as the start can be identified.
                      AyoA 2 Replies Last reply Reply Quote 0
                      • AyoA Offline
                        Ayo @fde101
                        @fde101
                        Sounds good if the starting node manifests itself as a smooth or cusp node for what it is. I think that's the main goal. Option to outline/color it differently in: Settings > Indicator Styles > Path Editing Indicators, is up to the user.
                        End node can be dropped as a special node symbol, my idea or I must overlook the function.
                        The only problem left is the path direction indication.
                        Dit is usually logically solved with a triangle/arrow shape, but with the convention of cusp=square and smooth=circle an additional dot does not provide this information in these symmetrical shapes. In addition, an extra dot does not contribute reducing visual clutter (Initial issue).
                        • AyoA Offline
                          Ayo @fde101
                          @fde101 I remember Astute graphics.
                          It shows a direction indicator when hovering over a node or path. Something like that (+ a modifier key) could be an option.
                          From the PathScribe Documentation
                            Of course the other way to handle this is to split the "Path Starting Node" and "Path Ending Node" options into "Path Starting Cusp" and "Path Starting Smooth" (or "... Ending ...") options (and similarly with "Selected..."), maybe add a rounded triangle shape and one or two others to give more variety... and allow each user to handle it through customization. Maybe split the color options as well between cusp and smooth (or between starting and other)?
                            • AyoA Offline
                              Ayo @fde101
                              @fde101
                              This looks a bit over-engineered to me and doesn't make things easier for the user (cockpit panel fighter jet 🙂)
                                debraspicher
                                I'm fine with it being a toggle in a panel or a toolbar. I don't need to be able to change it to the batwing symbol or anything. Though that would be cool.
                                32GB RAM @ 6000MHz
                                  I just need to be able to hide it 100% in a way that is also remembered between program starts. Sticky.
                                  I simply don't need tons of visual information that is not relevant for me, ever. Once I disable it, I will never enable it again.
