Best way to Crop an Image?
 @pw said in Best way to Crop an Image?: Sure! I simply want a crop or clipping tool to be able to select part of an image and have it cut out to that area. In one easy step. Drag around an area by pressing down on the left mouse button. That would specify the area to keep by pressing a button or checkbox or clicking on a menu item to accept the action. Very simple. And this is not easy ? Position a Rectangle over the Area you like to Crop
 (could be any Vector Shape)Select your Picture, put it in the Clipboard
 Ctrl-XDouble click on the Rectangle (left mousebutton)
 (and you are in Clipping Mode)Past your Picture
 Ctrl-VDouble Click on the Canvas
 to leave the Clipping ModeDone Edited: Typo
 Double Click again on the Rectangle
 should be
 Double click on the Canvas
 Hi, In this case, I was trying just to crop a jpg photo. Thanks -pw
 @pw said in Best way to Crop an Image?: Hi, In this case, I was trying just to crop a jpg photo. Thanks -pw see my post above
 Bitmap format doesnt matter as long as
 you could import it in VS
 I couldn't that to work but thanks. Not as simple as using the mouse to draw around an area then pressing the enter key. -pw
 @pw said in Best way to Crop an Image?: I couldn't that to work but thanks. Not as simple as using the mouse to draw around an area then pressing the enter key. -pw Most of us here found Vectorstyler because of its exceptional vector features at a price that is far, far from Corel's and Adobe's rather high prices. It's like a date, if you leave your date immediately on a single flaw, you may be leaving the person who will follow you faithfully through thick and thin. I agree that such a program here, when it supports JPG and bitmap, should also have a common tool like crop, and you should know that the programmer behind VS has improved the program significantly and quickly several times, so it's not a shortcoming that necessarily persists. I haven't seen a program before where it pays to be optimistic and keep up like this.  I can certainly recommend exploring the vector toolset, and for bitmap there are also quite a few image effects, so apart from crop I don't really think anything is missing. On the bright side, having used many of the major programs for decades, I can tell you that I have waited for bug fixes for years or months or in vain in other programs, but many really annoying bugs in Vectorstyler disappear in a few weeks. By comparison, I've waited for several bug fixes in other programs since way back in 2002. And never before have I seen them fixed as quickly as in Vectorstyler. Not even close.
 Thank you. I just wanted to use part an image for something and thought it would be nice to not have to switch to another program to do that. Seems like something like that is kind of expected. I will check out the features again of VectorStyler to see if I can use and adapt to it. And if I there is anything that it does that I am missing. No, I will not rent software for life from Adobe! Even if I had a big company to pay for it! -pw
 well said
 By the way, there are yet other ways to crop a bitmap in VS
 Simple Crop may be a little fasterBut the clipping method has a few advantages -
you can use any vector shape for cropping/clipping
you can rearrange the clipping area at any point you like - double click on the clipping object
 rearrange your bitmap
 double click on the canvas
 done
The whole thing works non-destructively, the original bitmap
 will not be changed. Only areas are covered.
Your vector object (Rectangle) can still be edited
 If you have any further questions, your welcome to ask them in the forum If you like to share Ideas to make VS better your welcome to
 post it in the "Features and Ideas" Section
 Can't seem to find the crop tool ?
 Where is it.. have read thread but can;t work it out
 @ambros There is a new crop tool in 1.2:  But remember that it odes not alter the image, only its clipping frame.
 @VectorStyler . Got it thank you
 works very well.. did exactly what I hoped it would do
