Adding white noise to a specific color in a color gradient
@Pat There should be a Create Object Style in the preset creation dropdown.
@VectorStyler Thanks
However, I'm applying the style to the object, making changes and it's not possible to update the style (I don't see how?):
@Pat The "preset" can be updated by selecting the object and the preset in the list.
@VectorStyler no, I don't see how it works and when I select an object with the object style, in the style list, what becomes selected is the image effect (noise), impossible to maintain the selected object style:
@VectorStyler I'll sent you the file to get help on this
Thanks
@Pat This is the Styles panel: the "Styles" are linked, so when an object is selected its used styles are highlighted in the panel.
To update styles here, the selection in the panel must be changed after the object is selected.I got the file, and it seems there is an offset path error with the stroke alignment. I opened a bug on this.
@VectorStyler Sorry, these are "words" but I can't visualize the issue here. It seems that it is what I do.
Could you please make a few print screens to help... ? I don't see what I do wrong or is it the bug that's blocking me doing this?...
@Pat I will try to create a better explanation, but in the document I got in the Styles list there is no Object Style or Image Effect style, probably was not saved.
@Pat Found the image effect, here is a recording of how to update the Object Style: https://recordit.co/grpBAFqEso
@VectorStyler Many thanks for your time
@VectorStyler No, I can't get it. I did watch carefully your video: I first select the object and then the object style in order to update the style... but doing so, I do change the object style before I can even change the style. Well, I'll try with another new file later.
@VectorStyler Also, why can't I edit the style:
@Pat said in Adding white noise to a specific color in a color gradient:
Yes, it means that in the panel menu "Listing Mode" the "Edit on Double Click" is enabled and apply is done on single click.
In which case, updating will not work (conflicting settings). Enable "Apply on Double Click".There is also "Update from Selection" in the Panel Options, that can be used to disable automatic highlight on object selection.
Object styles contain all sorts of attributes of an object and they cannot be edited in a separate modal view.
@VectorStyler Thank you
That's what I was doing but had forgotten about this single/double click... hence my lack of understanding.
