    I'm a bit lost in options
    18 Posts 4 Posters 14.0k Views 3 Watching
      Hi @Markus, Happy new year
      i refer to your "keep the aspect ratio" question
      in the "Settings" > Edit > Settings
      set "Proportional Object Scaling" may be helpful
      Editing > Proportional Object Scaling
      • ? Offline
        A Former User
        Oh, thanks a lot. ... I've just enabled them all.
        Though I cannot refrain from nitpicking. VS is not using my mouse input to the maximum of niceness (sorry, I'm out of words for describing things).
        When proportional is on, it seemingly wants me to move the mouse along the line that results from scaling.
        In other software I think it was more like this: Err.. when you move too much left or right, it compensates it in some way. Or in other words: There is some math missing in VS that makes scaling not jittery. But I'm out of words here.
        Thank you a lot!!
          Boldline @Guest
          @markus said in I'm a bit lost in options:
          By chance do you have the snapping enabled? In the upper right corner of the screen
          0_1704137712284_dfd25832-e57d-4cfa-818e-a36d2f82907e-BLD 2024-01-01 at 14.25.26@2x.png
          • ? Offline
            A Former User
            No, the snapping isn't it.
            It's just the way it's handled. I cannot explain it exactly, but when I was using other vector editors, it usually behaved something like this, afair:
            In other software there is the pivot (anchor, fixed point), just like in VS I guess. E.g. when I start dragging the upper right, then the pivot is the bottom left.
            And then there is the scaling amount that is the [current mouse position] minus [the mouse position when dragging started]. And from the x and y components of this vector, the highest (max(x, y)) is used, and the proportional scale uses that.
            In VS:
            I think it's more like this: There is a transform that will result in the handle being at the new position. So I have to move the mouse along this "thought line" in order to satisfy it (this transform that will). Or in other words: VS uses the inverse that min()-dependant transform scaling of my bad mouse input, so to speak. VS is correct, but I don't like it because the shape will jitter, because I'm bad at moving along lines that exist only in the imagination.
            Well, maybe try Inkscape or Xara and see how they make it less of a jittery (but not so mathematically correct, maybe) experience. I'm too out of UX knowledge to explain what I mean. I just can say "it's jittery for me".
            PS: Even if my explanation of VS was wrong, VS uses a "x/y decision" more like min(x, y) which often results in a small shape that doesn't touch the mouse cursor by far. So, it's just hard to maintain scaling it in a nice way, because the mouse is somewhere else.
            Thanks 😉
              VectorStyler @Guest
              @markus
              Yes, this is the case. Should it be the maximum?
              • ? Offline
                A Former User
                I think there's many points to be aware of (e.g. VS defaults to that AI-touch-selecting and users may tend to make smaller ways with the mouse?), but .. isn't choosing one dominant component like asking the user "how do you want to tell me the amount"?
                And then the maximum component would be the intention, and the minimum component would be the error.
                That is... if the user doesn't try to follow a imagined line, which is quite easy to do when you scale a rectangle (you always see the corner below the mouse pointer), but hard to do when there's nothing below it (scaling an ellipse or a small rabbit etc).
                I would vote for max(x, y) but I'm now downloading Inkscape and Xara to see what I have been accustomed to.
                • ? Offline
                  A Former User
                  Well, hard to tell. Problem with min(x, y) is that you need to "make room", at first, with the component that you don't want to control.
                  Make a shape like width:1 height:2 and start dragging at the upper right corner. When I do that, I have always the feeling there would be a hidden constraint -- until I go to the very right with the mouse cursor, then I get the feeling I can control the visually dominant size component (height: 2) quite well, which is a pro for VS/Inkscape. That is what VS and Inkscape seem to do. VS renders a bit laggy and gives me the impression of insufficient control, to some extent.
                  So, while VS and Inkscape do min, Xara does max. There the impression onto me of control is immediately there, no need to make room with the other component at first. But then, there's the drawback that the bigger size component of the shape will overdraw, going out of the page easily.
                  Problem for me is just the initial constraint of control, so I prefer max(x, y), or, what Xara does. I believe Corel Draw does this too (?), for the sake of "easy control". Anyway I love that feeling of getting something done, but if VS needs to stay with some kind of "exactness" (controlling the most occupying side), I will not interfere. 🙂
                  (please make it like Xara, lol)
                  Best regards
                  PS: The jitter is a result of trying to follow the imagined line that the handle will make when scaling. Every few seconds, when moving exactly along that line, one will not be precise enough and fall under the constraint (the no-control-intentioned component is too low) and the scaling won't update (there is no new accepted size), at least in VS that was my impression.<- ***
                  So, "making room" is a must. That makes it kind of special.
                  Edit: *** Maybe that could happen, sounds somewhat plausible, but I was trying to explain that "jump", see below.
                  PS2: I was playing around with VS again. It does something different than Inkscape. In Inkscape when, while dragging the size (proportional, ratio is locked) I move along that "scale line" after having dropped below the height of the shape, it will scale smoothly. VS, again, after having gone below the height of the shape, will make the shape size jump between small and big. And after dragging size for a minute or so, my integrated intel graphics (and complete Windows) will say bye with a video_dxgkrnl_fatal_error. Tested two times 😉 Maybe I'm running out of some video memory? Anyway, now you know.
                    VectorStyler @Guest
                    What is the setup you have (CPU. GPU)?
                    Does this happen when zooming in/out or panning with the mouse?
                    • ? Offline
                      A Former User
                      @VectorStyler said in I'm a bit lost in options:
                      Processor 11th Gen Intel(R) Core(TM) i5-11600 @ 2.80GHz, 2808 Mhz, 6 Core(s), 12 Logical Processor(s)
                      Using the integrated graphics, which is a Intel® UHD Graphics 750
                      Installed Physical Memory (RAM) 16,0 GB
                      I don't know whether it may happen when zooming. Today I could not reproduce it whatsoever. It didn't crash at all, even after zooming (in out, holding down ctrl+numpadminus+numpadplus when it gets into flipping between two zoom values) for 3 minutes, dragging shape size for 2 minutes, zooming for 3 minutes. It's stable.
                      One thing to keep in mind is that I have Windows click-lock on. Nobody would hold down the left mouse button for a minute.
                        VectorStyler @Guest
                        I did a google search on this error, I think it might be some other issue.
                        • ? Offline
                          A Former User
                          Just to describe it more in detail: It began not updating the VS window, VS ellipse didn't scale big/small anymore for 1 second, next second: mouse cursor froze, after that the whole display stayed like this about 2 seconds, then BSOD with that message.
                          This occurred two times in exactly this way, though, the second time without chrome opened in the background, just VS, since I had rebooted. So, VS seemed to trigger it, but I think the Intel drivers are ultimately not the best and could just be to blame. Also, I think the problem is super rare and you don't need to do anything about it.
                          Thank you in any case 🙂
