    Why is the New Layer Preview default an Orange fill?
    10 Posts 5 Posters 8.4k Views 4 Watching
      When creating a new layer in any VS document, is there a reason the preview in the layers panel is a solid orange color? As soon as I draw in that layer or paste a vector into it, it changes to reflect the new objects.
      Would it make sense for this to be empty or white?
      0_1704065348909_a5505b31-0510-4987-9e42-f144b087efc1-BLD 2023-12-31 at 18.27.11.png
        FastVector
        In Windows it doesn't have a 'fill'.
        Windows 10 | 1920x1080 | 125%
          FastVector
          Go to the hamburger menu of the Layer panel > Panel options > checkerboard
          first color = EFEFEF
          second color = CFCFCF
            @Boldline The empty layer preview should not be orange (or red) is should be a an empty checkerboard.
            Send me the file where you have this empty layer.
              @VectorStyler Just an FYI, I was using the regular non-beta version of VS on my old Mac running El Capitan and there was no issue with the default color fill in the layers panel
              • K Offline
                Kumr
                @Boldline @VectorStyler I noticed the same.
                  VectorStyler @Kumr
                  @Kumr @Boldline Looks like this occurs on MacOS Sonoma in both cases.
                  What happens if ou double click on the preview box (should open a larger preview)?
                  • Devil DinosaurD Offline
                    Devil Dinosaur
                    Works normally here with Sonoma (both regular and beta version), every new layer has a checker fill.
                    Fred.
                    • K Offline
                      Kumr @VectorStyler
                      @VectorStyler When I double click.
                        FastVector @Kumr
                        @Kumr I think this is normal. It magnifies the layer, so, when the layer is filled with objects, you can see the things that are in the layer.
