    Alternatives for 'drawing place' icons
    18 Posts 4 Posters 16.3k Views 4 Watching
    • AyoA Offline
      Ayo @VectorStyler
      Drawing Mode Icons and what became of it
      Previously I made non-binding proposals for the drawing icons in this section because I thought it could be better.
      Although it was still a sketch at the time not optimized, I now see that something has been done with it. It's just a shame that it has now become even worse. The icon set barely has any visual difference. And the highest contrast for the active part/subject is in the wrong place.
      The editors of Vectorstyler do not have to adopt my ideas, but if they do something with them, make them better. The old set, ugly and incoherent as it was, was better at being distinguishable. You get used to that.
      VectorStylerV H 2 Replies Last reply Reply Quote 1
        b77 @VectorStyler
        @VectorStyler What is the best way to distribute the custom icon set I made?
        As .vswork files or as the new .vsicon?
        .vswork is limited to the icons of the toolbox and the first
        row of the context bar.
        .vsicon allows me to change all the icons of the app but I'm not
        sure how easy it is to install it.
          VectorStyler @b77
          @b77 said in Alternatives for 'drawing place' icons:
          .vsicon is better. In this way the icons can be used "globally" in the app, not just inside a toolbox.
            VectorStyler @Ayo
            @Ayo Yes, there were some changes. The problem was at it did not work well in the dark theme.
            I will try to make these icons look better.
            • AyoA Offline
              Ayo @VectorStyler
              @VectorStyler How about something like this?
                VectorStyler @Ayo
                @Ayo I will try to add these.
                • AyoA Offline
                  Ayo @VectorStyler
                  Sent you this file as outlines in case this is useful.
                    VectorStyler @Ayo
                    @Ayo said in Alternatives for 'drawing place' icons:
                    Got it, thank you 🙂
                    • H Online
                      Harry @Ayo
                      @Ayo You are right. Here's how it looks on a 17" laptop—you barely see the difference.
                      But - from some distance, the pencil and the circle remind me of a magnifying glass:
                      • AyoA Offline
                        Ayo @Harry
                        @Harry
                        Thank you.
                        You're right, that association also occurred to me. Now I have placed the pencil a little further away (as far as possible because space is limited in a square) and more away from pointing towards the center of the circle. Think that's better.
                        Send an update of the file to Vectorstyler.
