Documentation: No "Limit" options for Grid Panel
The documentation for the Grid Panel (under the Grid Panel section) says:
- Limit - Edit the smallest spacing in pixels, for showing a grid cell. Grid cells smaller than this limit are not shown. This option affects only the display of the grid.
There's no "Limit" in the panel. Even the screenshot in the docs doesn't show it. Possibly a left over from an old version?
Link:
https://www.vectorstyler.com/documentation/guiding/grid/ -
@pentool If you click the Edit button at the bottom of the screen you can
edit additional grid options in the Grid Editor, and there you can set the
'Limit' value.
I see. Well, this is not clear from the documentation. But thanks for pointing this out.
@pentool Yes, it was removed from the panel and only available in the modal view. I will update the documentation.
