    Ideas to improve the Vectorstyler Layers Panel
    50 Posts 8 Posters 125.0k Views 6 Watching
      b77 @Ayo
      @Ayo said in Ideas to improve the Vectorstyler Layers Panel:
      Dimming the empty layer triangle confuses me. Looks like layer or something is disabled.
      Would an empty triangle look better? Empty shape β€”> empty layer.
      alt text
      • AyoA Offline
        Ayo
        We must be careful not to get bogged down in a discussion of details led by personal preferences. I am glad that the basic concept is being embraced. There is now enough food for thought for the developer to make his own choices if he wants to bring this idea to life.
        We should not only focus on the design of the panel alone, but also in conjunction with the style and concepts used in other parts of the program.
        A closely related panel is the Appearance Panel. The same principles can or must also be applied there. If the Layers Panel is going to change.
        I come to a summary below of course from my preferred point of view.
        Of course there is still more room for improvement. In line, color, level separations and icons of course. To avoid exponential numbers of variants you would first have to make fundamental design choices. We could proceed from there. But that's up to the developer.
        Speaks for itself, but the following things have been done at C.
        • Color IDs to the right
        • checkmark lighter weight
        • gridlines darker (instead of lighter) in Dark Mode
        • removed border Color IDs (not shure if that is wise)
        • some more new icon suggestions in footer.
        @Subpath Tanks!
          For me, I can definitely say no to the many attempts at improvement I see in Affinity and other programmes. They don't succeed because there is usually a confused effort with no science or UI education behind it. And yes, I work with usability every day.
          Keep it simple!
          In v2, Affinity has completely destroyed the most important thing in the layers panel for me, a quick overview of the content. A complete amateur chaos of lines and icons - and Serif did this because they think they can do without UI specialists. I don't lock, colour or hide objects all the time, but I navigate the left side of the layers panel constantly and all the time.
          It is absolutely crucial for me that the structure of the content and thumbnails are easy to read for quick use (left side with no Linux grid and symbol spaghetti), and the name afterwards is important, secondary. After that, locking and hiding content is less important - on the right side, for WHEN I need it. Tertiary.
          I guess this can be solved with customisation options, but basically my message is, FFS, don't ruin the current simple layout for me, which works great in designs with hundreds of objects. πŸ™‚
          • AyoA Offline
            Ayo @Ingolf
            @Ingolf said in Ideas to improve the Vectorstyler Layers Panel:
            I do!
            Keep it simple!
            Totally agree!
              b77 @b77
              @Ayo If the developer would implement 'Auto-lock' for inactive layers (meaning that
              you can select objects only on the active layer(s) and switching to another layer can be
              done simply by Cmd-clicking an object on that other layer), the 'lock' button for layers
              could be left somewhere on the right.
              And btw, since you work in cartography, would an optional 'Auto-hide' for the objects
              on inactive layers go well with this auto-locking of layers?
              @Ingolf If possible, can you include two screenshots with v1 and v2 of AD's Layers panel?
              I searched them a bit but I'm not sure those I found are not from AD's Pixel "Persona",
              which might look different (I guess).
              AyoA IngolfI 2 Replies Last reply Reply Quote 0
              • AyoA Offline
                Ayo @b77
                @b77 said in Ideas to improve the Vectorstyler Layers Panel:
                I'm not that fond of 'Auto' or self-thinking functions
                  b77 @Ayo
                  @Ayo Not clear if you did work in an app that has this alternative mode and didn't like it,
                  but all right…
                  I'm asking because auto-locking of layers makes both restricted selecting of objects
                  and jumping to another layer much easier and faster, since you don't need to walk
                  the mouse all the way to the Layers panel, and locking other objects to avoid selecting
                  them becomes unnecessary most of the time.
                  So in this case at least these buttons can be left on the right side of the Layers panel.
                  (I'm not advising for this mode to be enabled by default, but… with big monitors these
                  days I think it would help a lot).
                    Ingolf @b77
                    Version 2:
                    Pure crap UI:
                    Compared to the absolute calm and no nonsense interface in version 1 I NEVER had trouble using or navigating in. Everything from this point and 'up' should be opt-in.
                      fde101 Global Moderator @b77
                      Well, I personally still like the filled eye better.
                      My own take on it: checkmark for visible and printable/exportable, eye for visible but non-printing, printer or paper icon for printing/exporting but not visible in normal edit mode, none for invisible and non-printing.
                      Normal left click toggles between none and whatever it was set to of the three other options. Right click opens context menu to pick from all four options.
                        b77 @fde101
                        @fde101 I'm not sure a 'printable' button is needed? Currently if something is
                        not visible it doesn't get printed or exported.
                        Except for the grid and guidelines. Hmm… πŸ€”
                        In any case, I would say that…
                        'Printable' β†’ small printer button β†’ no reading of the manual needed.
                        CDR has it like that β€” a 'printer' button for objects, guidelines and for the grid in its
                        Layers panel (named 'Object Manager'), along the 'eye' and 'lock' buttons.
                        • AyoA Offline
                          Ayo @b77
                          Are there other graphics apps using a validation sign in the Layers panel?
                          Came across this.
                          Nice variation. Layers panel –I suppose– on the left hand side this time. On/off (with checkmarks) on the panels right side, close to the users working center.
                          From earlier post today: Toucan
                          Home/General Discussion/The first vector graphics editor built for generative design
                          • AyoA Offline
                            Ayo
                            a final argument for the checkmark : )
                            b77B BoldlineB 2 Replies Last reply Reply Quote 2
                              b77 @Ayo
                              @Ayo I beg to differ, the eye is staring you in the face. πŸ™‚
                                b77 @b77
                                All right… in all seriousness, I have to acknowledge that there are indeed
                                vector-based apps that use a checkmark for layer and object visibility
                                (and export) instead of an eye. Some because the functionality of their Layers
                                panel is simple, some other despite the complexity (Affinity, I guess).
                                To me a checkmark still seems too generic (it doesn't scream 'visibility').
                                Besides that, there are other places in the app where the concept of 'visibility'
                                is used (Hidden object, Show All Objects, New View, Select All Inside View),
                                and I don't think using a checkmark in the icons of these commands would work.
                                (I'm trying to make icons for these commands as well, so we could continue
                                the discussion when I post them on the forum. The icons won't be perfect,
                                I'm sure).
                                OK, said enough about this, I rest my case. πŸ™‚
                                • AyoA Offline
                                  Ayo @b77
                                  @b77 Don't take it too seriously. Was just a design joke. We are all in the first place designers, aren't we?
                                    b77 @Ayo
                                    @Ayo Absolutely!
                                      Boldline @Ayo
                                      No offense @b77 , I do like the streamlined look of the one @Ayo whipped up. It would be cool with some special effects and the cursor cross icon in there
                                        @Boldline Ayo made a joke, I also made one β€” that's it, nothing more.
                                          @b77 joking aside there's some real potential there
                                            @Boldline Let's not go off-topic and mess up Ayo's thread.
