    Posters using VS: from blend, image effect,... to pattern etc.
    30 Posts 3 Posters 59.1k Views 3 Watching
    • B Offline
      B-Vs-V
      I can add 'effect on the stroke':
        Subpath @B-Vs-V
        @Pat
        Guess its a blend in the middle.
        Find that can certainly keep up with the with a Particle brush
        from Flamepainter.
        For anyone who is interested hier a Link:
        https://www.escapemotions.com/products/flamepainter/about?//products/flamepainter/index.php
        • B Offline
          B-Vs-V @Subpath
          @Subpath yes, quickly done to place a graphic in the middle but I should have taken a bit more time to finish it ☺
          Nice apps but are they vector or bitmap ? I guess bitmap...
            Subpath @B-Vs-V
            @Pat said in Posters using VS: from blend, image effect,... to pattern etc.:
            looks good to me as it is 🙂
            yes, the result of Flame Painter is a bitmap it has a vector output,
            but this is in my eyes totally useless.
            The vector graphic import is one of the things i like in
            Flame Painter. Works via vector layer, only one path is allowed
            per vector layer, but many vector layer.
            You can import an .svg path from VS and put any particle brush on it.
            The whole thing remains resolution independent internally until its exported.
            I will post something here where I have recreated a graphic in VS which
            i made with Flame Painter. But that will take some time.
            • B Offline
              B-Vs-V @Subpath
              @Subpath Would be great to see here what can be done with VS & FP ☺
              • B Offline
                B-Vs-V
                @VectorStyler When I sent you the 5-artboards file, I described an issue with colour blending that I could not see in the pdf file after export (artboard n°3). Could you reproduce this issue?
                Thanks ☺
                  VectorStyler @B-Vs-V
                  Yes, I noticed are several problems on artboard 1 and 3. I added this to the backlog, but could not yet find a solution.
                  • B Offline
                    B-Vs-V
                    For what it's worth... an attempt to recycle some previously produced graphics. There some issues with pdf export and colour blending.
                    Mesh, mask (gradient mask), blending, transparency, transform...
                      @Pat yes, some of these PDF exporting issues can be replicated here also.
                      • B Offline
                        B-Vs-V
                        I wanted to test the knife tool and then the contour tool and the pdf export.
                        It was first a sphere that I cut in 3 parts (knife tool) and I've applied the contour tool (Q), changed the stroke profile etc.
                        Many options & some glitches but fun to use... this is an exported pdf cymk, therefore the colours are a bit... well less vivid than in rgb ☺
                          Subpath @B-Vs-V
                          @Pat
                          like the colors
                          the contour looks nice too
                          • B Offline
                            B-Vs-V @Subpath
                            @Subpath thanks but this is very simple because it's mainly to learn (and memorise, which is more difficult 😀 ) the many features & functionalities of VS.
                            I'll start a bigger project when I'll have more free time.
                              Subpath @B-Vs-V
                              Yes, this is also one of my main fun when creating tutorials
                              and you always learn a thing or two too, when you have to explain a thing
                              • B Offline
                                B-Vs-V
                                Very simple design almost monochromatic - Blending, colour gradients & white noise, transform
                                  Subpath @B-Vs-V
                                  @Pat
                                  great, like it
                                  even for the color
                                  good has nothing to do with complex designs 🙂
                                  so, no need to excuse for simple things
                                  reminds me a bit on "Russian Futuristic" graphics style
                                  • B Offline
                                    B-Vs-V @Subpath
                                    @Subpath Thanks ☺ well I don't really know what is this kind of design but I'll look for it ☺
                                      Subpath @B-Vs-V
                                      @Pat
                                      "Russian Futurism" is a kind of painting style
                                      from the 1920 i guess
                                      and there was i time where kind of modernize
                                      graphic style came up which going back to this graphic
                                      style language
                                      Here a link i found, not really what i meant
                                      but gives a impression
                                      https://www.google.de/imgres?imgurl=https%3A%2F%2Fmir-s3-cdn-cf.behance.net%2Fproject_modules%2F1400%2F6d57ea38406405.5766c7842bf3d.jpg&tbnid=geLceAPiDX9SBM&vet=12ahUKEwiiwoKk1YSAAxWJmycCHYh2DrIQMyg3egQIARBJ..i&imgrefurl=https%3A%2F%2Fwww.behance.net%2Fgallery%2F38406405%2FHistory-of-Russian-Graphic-Design%3Flocale%3Dde_DE&docid=Nkzbp2oYp8shOM&w=1400&h=1277&itg=1&q=russian futurism graphic illustration&ved=2ahUKEwiiwoKk1YSAAxWJmycCHYh2DrIQMyg3egQIARBJ
                                      • B Offline
                                        B-Vs-V
                                        Well, I'll finish the thread with this one for now... VS, it's so much fun and creative to play with, all these shapes and distortions etc.
                                        The starting shape is only one circle ☺
                                        • B Offline
                                          B-Vs-V
                                          I've tried to get a particular poster-look 😕😖 but stop now before it is finished because with the blend function for several objects with gradients, VS becomes rather slow.
                                          • B Offline
                                            B-Vs-V
                                            Testing new features, just for fun and WIP:
                                            S 1 Reply Last reply Reply Quote 4
