    Unlock icon symbol idea for the layers panel
    11 Posts 5 Posters 8.8k Views 4 Watching
      Subpath @Boldline
      Well, it's maybe not so obvious if it's open or not, especially with small icon/high resolution.
      But I have no problem with your version.
      BoldlineB b77B 2 Replies Last reply Reply Quote 1
        Boldline @Subpath
        @Subpath True, it's not quite as obvious as the current overhang hook. Two reasons I felt this was a better option;
        It keeps the unlock icon the same size as the Lock icon
        It also is still easy to read if you remember that filled lock is "locked" and outline lock is unlock
        Just makes the layer panel look more sleek and compact in my opinion. Whatever @VectorStyler decides....
          b77 @Subpath
          @Subpath All icons, big or small, look better and clearer on a high res monitor.
          You need a high resolution monitor in your life. 🙂
            Subpath @Boldline
            as i wrote no Problem with yor Version, just my thoughs
            I know someone could remember the different states
              Subpath @b77
              ... You need a high resolution monitor in your life ...
              been looking allready around already the last few weeks 🙂
              thinking about a 32" 4K Monitor but choosing the one i like
              will yet take time
              • Victor VectorV Offline
                Victor Vector
                @Subpath
                https://www.amazon.de/-/en/PD2705U-Designer-Monitor-Technology-Compatible/dp/B096B3PBFZ/
                32" would be nice for sure! If you are looking for something that might be a bit less expensive, the above may be a good choice. I have a 27" monitor about 30" (76 cm) away from my eyes, and I still have to turn my head slightly to see to the edges without shifting my eyes left or right uncomfortably. So a 27" can definitely fill your periphery!
                My apologies for going off-topic. I couldn't resist as new hardware is always exciting! 😂 😀
                  Subpath @Victor Vector
                  @Victor-Vector
                  I am currently using a 40-inch monitor and thought a 32-inch monitor
                  might be okay too. Where a 32-inch monitor is my minimum. I had
                  a 27-inch monitor before, but it find it too small for my needs.
                  I prefer to edit vector graphics on a large monitor and a lower resolution (actually 1440x900).
                  I find that more comfortable to work with the thin vector curves.
                  Victor VectorV IgullI 2 Replies Last reply Reply Quote 0
                    Victor Vector @Subpath
                    @Subpath I have a better understanding of your set up now, thank you. Seems like a good approach. Nice to have a big monitor!
                    • IgullI Offline
                      Igull @Subpath
                      @Subpath said in Unlock icon symbol idea for the layers panel:
                      @Victor-Vector
                      LOL, I can still remember MacDraw on my wee MacPlus and thought that was huge ☺
                      I like the large monitor/smaller resolution concept idea, a 27" retina display is nice, but can sometimes be a little over-crisp for general line drawing - I might borrow the house TV and see how that goes 🙂
                      Neil
                        Subpath @Igull
                        @Igull said in Unlock icon symbol idea for the layers panel:
                        ... I might borrow the house TV and see how that goes ...
                        would say it works well 🙂
                        i use actually a 40-inch Samsung TV Monitor
                        ... but can sometimes be a little over-crisp for general line drawing ...
                        That is the reason why I came up with this idea.
                        While my eyesight is ok, I found this combination a little more relaxing
                        to work with vector curves and nodes.
