Simple Rotate Question
  • OK, imagine a random line at some random angle - let's say 12 deg - manually rotate it using the transform tool with the shift key held - should the line rotate by 90 deg (ie to 102 deg) or rotate to 90 deg ????
    My thoughts are that it should rotate BY a fixed 90 deg and not be forced to 0/45/90 or whatever pref has been set ???
    Or tell me, there's a pref/option/ctrl/method that I can't see for this ☺ ☺
    I use the wonderful collider tool a LOT in my stuff - that very neatly sets the line at the correct angle, but I then might want that line at 90 deg to this new angle - that's my thinking behind this 🙂
    TIA
    Neil
    @Igull Currently it rotates by increments of 45 degree
  • @VectorStyler said in Simple Rotate Question:
    OK, I've just backtracked through my process. If you create a line, then use the collider tool tool to lock it to another object's angle - then attempt to rotate it using the shift key, it doesn't rotate it through 45/90. It works ok if you create another line at the same locked angle - then rotate, but NOT when that line has been rotated initially using the collider tool (if that makes sense 🙂 )
    Neil
  • @Igull Shift-rotate basically jumps to 45° fixed quarters/divisions (horizontal, vertical and
    diagonal), not to 12° (or whatever the current rotation angle is) +/- 45°.
    I also suggested that this is a behavior that could be a (non-default) option in Preferences.
    @Igull said in Simple Rotate Question:
    Yes, in this case it changes the existing rotation angle to 90 degrees.
    A Convert to Curves will flatten the current rotation into the line.
  • @b77 said in Simple Rotate Question:
    Yes, for me, that would be a better option - or even an added modifier - cmd+shift say ??
    Neil
    Added this to the backlog.
  • @Igull If I'm not misunderstanding something, in version 1.1.080
    enabling 'Relative Angle Constrain' in Prefs > Editing Options 1
    does what you (and me) asked for.
    Yes, it does :-). Works fine too !
    However, wouldn't it have been better to just have a modifier key - say cmd+shift (or ctrl+shift for the winfolks) to do relative constrain or just shift to force it to orthogonal ? Having an option in prefs (Settings ??) seems a bit clunky ??
    Just my thought.
    Neil
    We are a bit overloaded with modifier keys already 😞
  • @Igull said in Simple Rotate Question:
    However, wouldn't it have been better to just have a modifier key…
    I would just prefer the 'relative' option to be on by default.
    @Igull You are doing technical drawings, IIRC.
    How many times do you need the fixed step rotation instead
    of the relative?
    of the relative?
    TBH, that's probably laziness on my part, but having both options available via a modifier key would save me having to use the collision tool to force the object back to orthogonal then use the rotate option - so, simply holding (say) the command key down would be relative - without, would force the object back to orthogonal.
    If it's a binary situation on modifier keys (surely a person can never have sufficient modifier keys LOL), then yes, having relative on by default is probably the better option.
    I fully realise that having more modifiers is creating a stick for Csaba's back, but it makes the delight of using and modifying VS such a great experience - once you have nailed down your own preferences and saved them, what a HUGE time saver it is. I do find myself going back to tweak my settings and improving the experience even more.
    May the fourth be with you 🙂
    Neil
  • @Igull Yes, a modifier for this would be nice. I don't consider it laziness, it's a fast workflow.
    But in my mind Cmd is connected to editing, not transforming an object.
    And it doesn't have a direct equivalent on Windows keyboards.
    @VectorStyler Could Ctrl-Shift for orthogonal rotation work on both Mac and Win?
    Btw…
    alt text
    May the 4th be with you. 🙂
    Added this to the backlog, I will check if this is possible.
    Still prefer command on Mac, could use ctrl on PC 'though. Ctrl has never been anything other than contextual on mac - it's also far far away in another galaxy - right on the edge of all the keyboards 🙂
    Neil
