    123 Posts 7 Posters 474.5k Views 7 Watching
      VectorStyler @B-Vs-V
      @Pat That button changes the starting node of the selected path to the selected node.
      Use the Stroke panel (or the Width panel) to change the profile.
      • B Offline
        B-Vs-V @VectorStyler
        @VectorStyler Yes, I know that but when I change the profile, the thinner stroke starts where I don't want. I thought that changing the start of the stroke might help to have the profile as I want.
          Got it, that should work! But it might be that the blend behaves differently if the starting node is shifted.
          I will test this.
            @Pat BTW: there is also a Blend Mapping tool (next to the blend tool) that can be used to realign blend shapes.
            • B Offline
              @VectorStyler yes, I thought of that and we should think about changing the starting point before blending.
              • B Offline
                @VectorStyler Ok, I have to select two nodes of the two blended objects before changing the start of the strokes and it is fine ☺
                • B Offline
                  @VectorStyler said in WIP - Testing Blending: not yet a tutorial but soon for beginners:
                  I don't find the way to change the stroke start with any tool (from the panel, right ?).
                    The Blend Mapping tool is in the toolbox and it does not change the stroke start.
                    It can be used to create a "mapping" from locations of one shape to the other for the blend effect.
                    So after changing the stroke start, and the blend breaks, the mapping tool can be used to realign the shapes (without further changing the start).
                    • B Offline
                      Ok, I see. I haven't used this feature yet but I'll look into it 👍
                      I notice that this thread has more than 8k views: for those who like abstract shapes & patterns & vector drawing & would be tempted by VS, don't hesitate ☺ I personally find the pleasure I had to use AI a long time ago (and that I never had with another app before VS).
                      @VectorStyler I'm looking forward to version 1.2 with all the new layout possibilities (hopefully) ☺
                        Subpath @B-Vs-V
                        @Pat
                        a nice stamp
                        will you sell it to the post office ? 🙂
                        • B Offline
                          B-Vs-V @Subpath
                            Subpath @B-Vs-V
                            @Pat
                            was kidding 🙂
                            • B Offline
                              B-Vs-V @Subpath
                              • B Offline
                                B-Vs-V
                                It's not the expected result but it's still interesting for multiple designs (posters for example).
                                1. create any design, by blending if you want and eventually group the different objects (ctrl+g)
                                2. write a text and do not convert to curves
                                3. apply a deformation to the text (here 'wave')
                                4. define the text as a shape (Object -> Object role -> Shape) and give it a name (e.g., Sh 1)
                                5. either (1) select the design and fetch the shape (e.g., Sh1) in the 'Shape' panel or (2) try to clip the shape into the text layer: for the moment, there may be some glitches and design shifts (that I don't understand) but that's the surprise side of VS ☺
                                as the text is live, one can write any word:
                                S 1 Reply Last reply Reply Quote 4
                                  Subpath @B-Vs-V
                                  @Pat
                                  nice one
                                  like the designs you do with blends 👍
                                  • B Offline
                                    B-Vs-V @Subpath
                                    @Subpath Thank you ☺
                                    I'm simply experimenting and without the need for a subscription 😀
                                      Subpath @B-Vs-V
                                      ... I'm simply experimenting...
                                      yes, i also like Vectorstyler for that
                                      and it goes deeper and deeper 🙂
                                      ...without the need for a subscription...
                                      who would need subscription for that 🙂
                                      • B Offline
                                        B-Vs-V @Subpath
                                        @Subpath Exactly ☺
                                        When one superimpose different designs with different colour blending (between layers this time ☺ ) - just a print screen ☺
                                        • B Offline
                                          B-Vs-V
                                          @VectorStyler update 1.1.082
                                          It is fixed... ☺ & now everything should be editable!
                                            Subpath @B-Vs-V
                                            @Pat
                                            isnt it crazy 😉
