    File crashes when opening
    32 Posts 6 Posters 70.2k Views 5 Watching
      Boldline @gotanidea
      For what it's worth, I tested the @coolio00111 file again with build 74 and it worked correctly. (it had crashed VS for me each time I attempted it in build 73)
        VectorStyler @gotanidea
        @gotanidea I keep this issue open, but I have to replicate it.
        So for it seems to be opening fine on both Windows 10 and 11, and also on Macs (Intel and M1).
        One thing to try is to restore the app to defaults by holding control+alt+shift while starting it.
          @gotanidea Can you send me the crash logs from the latest crash of 1.1.074
          • G Offline
            gotanidea @VectorStyler
            @VectorStyler I just emailed the crash log file, generated from the opening of @coolio00111 's file (the file name is 5 fold card_2.vstyler)
              @gotanidea One other thing: what is selected in the Preferences -> Performance -> Compute Engine?
              Try selecting software, restart, and then open the file.
              G 2 Replies Last reply Reply Quote 0
              • G Offline
                @VectorStyler I tried both Software and Nvidia CUDA Compute Engine.
                I also checked and unchecked the Rendering, Document and Image Threads. When they are checked, the values are 16.
                I have restarted my computer as well, but the files still crash VectorStyler
                • G Offline
                  @VectorStyler I found that it is the Links panel that always crashes VectorStyler. If we don't show it before opening the problematic VectorStyler file, the application will not crash.
                  To reproduce the crash:
                  1. Open any VectorStyler file or create a new document. Make sure the Links panel appears. Close it.
                  2. Open the problematic VectorStyler file. The application will crash.
                  The workaround:
                  1. Open any VectorStyler file or create a new document. Make sure the Links panel doesn't appear. Close it.
                  2. Open the problematic VectorStyler file. The application will not crash.
                  I tested this with the file I emailed and @coolio00111 's file
                  VectorStylerV 2 Replies Last reply Reply Quote 2
                    @gotanidea Thanks for finding the issue. Yes, sometimes panels (as are updated for the opened) file may be part of the problem.
                    I can replicate this on Windows (does not crash on Mac).
                    I will try to have the fix in the next build, meanwhile as a workaround, keep the Links panel closed when opening documents 🙂
                      @gotanidea I uploaded a new build that should fix the Links panel crash when opening files.
                      G 1 Reply Last reply Reply Quote 2
                      • G Offline
                        @VectorStyler Thanks Admin. I can open the files with the Links panel now
                          b77 @coolio00111
                          @coolio00111 said in File crashes when opening:
                          Also was having some issues where I would click a text box, be able to edit the text, then if I click the text box again, the text wouldn't be able to be edited. I would have to re-open vectorstyler.
                          If you find what causes this, don't forget to report it to the developer.
