Blends are not automatically transferred to cloned curves
Not shure if this is a bug.
Blends are not automatically transferred to cloned curves.
It works manually, on the other hand.the curves on the right side are the cloned ones
See Video here
Video
@Subpath is the blend (all 3 objects) in a group, and the group is cloned?
@VectorStyler said in Blends are not automatically transferred to cloned curves:
no, there is nothing in a group or grouped
When you look in the Video
i create two straight curves select them
an clone theman then i apply a blend on the original curves
and though the clones will also get a blend
but doesnt work
have to do it manualy
@Subpath Just duplicating, or cloning the two ends will not carry the blend over. This is by design.
that it does not work with duplicates is clear to me
if I manually blend the cloned curves it works as desired
but that the blending is not automatically is transferred
to the cloned curves, if i blend the two orinal curves
had me just wondered.
