    Some dragging operations (drag selecting or pan/zoom navigating) not responding sometimes
    20 Posts 4 Posters 19.1k Views 3 Watching
      VectorStyler @ncic
      @ncic I will try to replicate these, if you have more info on how to reach the broken state, please let me know.
      ncicN 1 Reply Last reply Reply Quote 0
      • ncicN Offline
        ncic @VectorStyler
        Here is a recording of the transform select V arrow stopping to work
        I can select other tools and selections and the choose the V arrow but the other tools are still active.
        In this clip you see me first trying to make a box selection with the V arrow but nothing happens.
        Then i experiment with selecting other tools and back to arrow V
        recording
        This happened after i have had the application idle in the background and entered it again after some time.
        MacBook Pro 16” M1 Max 64GB RAM
          VectorStyler @ncic
          @ncic Got it now. The magic wand selection mode is active (in the toolbox).
          Select the first one in here (the second is visible in the video).
            @VectorStyler said in Some dragging operations (drag selecting or pan/zoom navigating) not responding sometimes:
            Is this something you're still working on a solution for?
              @Boldline There is a task (for later) to allow box selection in magic wand mode also, but it will still act as a magic wand (select by style).
              So not for now.
                @VectorStyler Yes the box selection option for the magic wand will be a cool and useful addition when it gets added.
                The issue that @ncic seems to have had and that I've also run into is that when you are finished using the magic wand tool, you have to remember to go back over to the tool bar and swap it back to one of the other selection options. If it remains on the magic wand, then other tools do not function properly and it feels like VS is not working correctly.
                Perhaps the best answer for now is to assign a keyboard shortcut to the standard box selection? This way, when finished with the other selection tools, it's easy to hit a key and go back to "normal' selection mode? Or maybe the cursor has an asterisk next to it when in selection modes other than the standard rectangle select? that would at least give some visual feedback that something is different about the selection
                Another option could be to reverse the color of the icons for the other selection modes aside from the standard box selection so you can visually see that you are in a mode that needs to be switched back from to use other tools
                  Boldline @Boldline
                  Another idea would be pressing the same key a second time when done with the magic wand. ... so for example, once you are done using the magic wand, you press the "M" key to revert back to the box selection. the same would be true with the lasso and polygonal lasso (though to make this work a key would need to be assigned to the polygonal lasso)
                  Much the same way we can press "A" twice to flip between the node selection tool and the transform tool.
                    @Boldline The shortcuts can be assigned easily, and I can add them to the default sets.
                      My favorite option of the numerous potential solutions I was brainstorming in the earlier post in this thread would be the option to just press the same key of the current selection tool a second time to revert back to the main box selection tool (like the press "A" twice to flip between the node selection tool and the transform tool ability), but I think it would help if the cursor also had an additional symbol next to it when in those less used selection modes
                        Boldline @Boldline
                        @VectorStyler The magic wand no longer has the keyboard shortcut "M". I don't know if this was intentional or not. My initial thought was that we not get rid the existing keyboard shortcut, but add the ability to press the M key again to get back to the previous selection mode, etc... something like that
                          @Boldline said in Some dragging operations (drag selecting or pan/zoom navigating) not responding sometimes:
                          Yes it was intentional. I have the impression that sometimes it is pressed inadvertently and when activated, the box selection is not working anymore of course.
                            ok I can understand why you took it off for now. I liked having that shortcut there but I also agree that unless there's a solution for an easy return to the box selection, it will leave people confused as to what happened.
                              @Boldline Of course, it can be easily added with the shortcut editor.
                                Yes I understand that I can add it back in myself and short term, I'll probably do that. In Illustrator I'm used to having a designated keyboard shortcut key for the magic wand and I prefer it personally.
                                I'm still hoping that when a solution to the inability to switch back to the box selection from the magic wand comes along, the magic wand can officially have a keyboard shortcut (along with the other selection tools in that section) to allow for quick switching - much like we discussed today about giving most tools the ability to switch back to the prior by pressing the same key again - in this case the "M" key
                                • ncicN Offline
                                  ncic @Boldline
                                  @Boldline @VectorStyler
                                  Great discussion
                                  From a personal perspective i find tools that are in the same toolbar category sharing the same keyboard shortcut toggling between them a bit problematic.
                                  Its ok in less used tools as it has the benefit of saving amount of shortcuts that are taken, but tools one switches between often is where ive found it more problematic.
                                  It introduces greater risk of accidentaly activting the wrong tool and therefore also increases the demand on the user to pay attention to the interface (for instance toolbar icons or cursor icon) or more cognitive load by remembering the amount of shortcut presses done so that the correct tool is selected before an operation.
                                  This is especially demanding where the toolbar item has maybe three to four tools that share the same key.
                                  For example the brush, pencil, color replacemnt and mixer brush in Photoshop are tedious if youre jumping between pencil and brush as you have to count every time to know where you are and to skip over tools to get to where you want.
                                  Alternatively the user could find out by error after using the tool. If its the wrong one, the user has to step back a few steps to redo the correct steps.
                                  Ive also experienced this leakage of focus and energy when using Clip Studio Pro that uses this type of method of sharing a shortcut between different tools in the same category.
                                  I stay away from customizing and apps shortcuts unless i really need too but i found in CSP because of this it became necessary to set more uniqe shortcuts for the tools used to avoid the problem described above.
                                    b77
                                    I updated the sortable shortcuts here:
                                    https://www.dropbox.com/sh/9g01l3la6nv5h1t/AAAF5kWrRhXamcsDlQEOwlh7a?dl=0
                                      Boldline @ncic
                                      @ncic said in Some dragging operations (drag selecting or pan/zoom navigating) not responding sometimes:
                                      Great discussion
                                      I agree with you overall, that would be confusing if they all shared the same key shortcut. I'm not advocating for using the same shortcut key for all tools in a section, but allowing the ability to hit the specific shortcut key a second time to go back to the original tool used located elsewhere in the toolbar completely. So if I'm using the pen tool and then tap on "m", I have the magic wand tool until I click "m" again and I'm back on pen tool.
