    • Users
    • Groups
    • Admin
    Document Units
    6 Posts 0 Posters 5.0k Views 2 Watching
    • IgullI Offline
      Igull
      When I open another document type (specifically AI or an SVG), VS always has the default units in points.
      Is there a way to override this to ensure everything is always converted to millimetres ?
      I've been through the manual/help files, but can't find anything suitable.
      TIA
      Neil
      V 1 Reply Last reply Reply Quote 0
      • IgullI Offline
        Igull
        Anyone got a solution for this ?
        Neil
        • V Online
          vectoradmin @Igull
          @Igull When creating a new document, set the unites in the General tab and confirm.
          Next time creating a new document (without setup) should use those units.
          • IgullI Offline
            Igull @vectoradmin
            @VectorStyler said in Document Units:
            Yes, creating a new document will use the same units, but opening an existing document - say an SVG or AI, will always default to points - that's my issue.
            The opened document doesn't use the default values used by the default VS document - nor does it pick up the units from an AI document (I can't remember if SVG docs uses sizing or whether it is always in DPI).
            Neil
            • V Online
              vectoradmin @Igull
              @Igull said in Document Units:
              Got it. I added this to the backlog as a bug.
              • IgullI Offline
                Igull @vectoradmin
                Powered by NodeBB.
