    Extend and Trim ?
    16 Posts 5 Posters 14.2k Views 4 Watching
      Subpath @Igull
      @Igull
      found here two solutions
      see Video
      you could also use "Snap to Shape"
      instead of Alignment
      I think this post is not so relevant anymore
      because the use of Scale works best
      • see my post below
        and another one in this video
        but i am unshure if this work in every case
        Is also not so relevant anymore
        • see my post below
          VectorStyler @Igull
          @Igull Uniform (Shift+) scaling of each line with the transform tool can be used to extend them. Then use the trim and join tool:
          https://recordit.co/rzmlB2ehcN
            Subpath @VectorStyler
            @Igull
            Found Menu > Object > Transform > Scale also useful
            and very easy.
            Because the Panel keep the Setting, useful if you
            have more then one open Spike
            see this Video here
            • IgullI Offline
              Igull @Subpath
              @Subpath @Vectorstyler
              Thanks for those, that's pretty much what I was doing currently - I had hoped that I was missing a specialist tool in the VS arsenal (maybe command+option+J 🙂 )that would just do it in one LOL 🙂
              However, the scale method using the transform tool is fair enough and not too tedious.
              Curiously, you can't do this in AI the way that you can in VS, in AI, you always hit the constrain (shift) key first and that doesn't allow the line to be extended without moving the origin - and if you don't constrain, you lose the vector angle. In VS, the origin and vector angle remain the same and allow you to extend the line - that's a +1 for VS !
              It's a fairly common type command in the CAD world to extend and join two vector ends.
              Thanks
              Neil
              S BoldlineB 3 Replies Last reply Reply Quote 3
                Subpath @Igull
                @Igull said in Extend and Trim ?:
                You're welcome, I always find it interesting to look for solutions to other users' problems. Because so I often discover tools that I
                never use in VS 🙂 and find of course new possibilities for me too.
                I also know the possibility to extend lines from CAD programs.
                Which I have used a few.
                  Subpath @Igull
                  I had hoped that I was missing a specialist tool in the VS arsenal (maybe command+option+J )that would just do it in one LOL
                  Maybe a recorded Action could help? To create such a miracle command.
                  If you record the Scale via Menu > Object > Transform > Scale Way
                  which I showed in my third post
                  • IgullI Offline
                    Igull @Subpath
                    @Subpath said in Extend and Trim ?:
                    LOL, I didn't even know about actions !
                    In this case, it's probably not really practical as all the extends I would do would be different lengths, but the concept of recording actions is great - I had a pile of scripts written in AI that I used all the time and may do something similar here. Having scripting is handier, but sometimes a repetitive command is just as easily recorded.
                    Thanks for pointing me in that direction. I did struggle to find the actions panel, but eventually found it lurking in the Presets menu 🙂
                    Thanks
                    Neil
                    b77B S 2 Replies Last reply Reply Quote 2
                      b77 @Igull
                      On the Mac the Help menu of most apps has a search field, so it's easy to type something there ('actions', 'convert', etc) and be shown where the command is in the menus.
                        Subpath @Igull
                        yes, Menu > Panel > Presets > Actions
                          Boldline @Igull
                          Can you explain how you extend the line while the origin and vector angle remain unchanged? Or was scaling it as @Subpath demonstrated in the video what you meant with this?
                          When i was trying to extend the line while keeping the origin and vector angle unchanged, I could not find any way to do this. I certainly leave plenty of room for my own user error in this case!
                          Unless I totally missed it, it would be great to see a modifier key used to constrain the angle and allow for a line to be extended from one side or an option to extend it from both sides at the same time.
                          I also liked the collaborated idea about an action to intersect two lines. So if you had two end nodes selected on different lines, the action would extend them until they met.
                          Both of these would be terrific additions to VS
                            Subpath @Boldline
                            maybe this video helpful
                              Boldline @Subpath
                              @Subpath Thanks - that makes more sense and is a creative solution. However it still feels like a lot of work to accomplish a simple task and if the user has "scale strokes and effects" turned on, they would have the added step of re-sizing the stroke after scaling.
                              @VectorStyler is it possible to add a modifier key to allow a path to be lengthened or shortened by adjusting the end node without compromising the angle or the origin of the other end of that selected line?
                                @Boldline said in Extend and Trim ?:
                                I added this to the backlog of 1.2. I think a separate action is better suited for this to avoid looking for modifier keys.
                                IgullI 1 Reply Last reply Reply Quote 4
                                • IgullI Offline
                                  Igull @VectorStyler
                                  Thanks, that sounds like a better solution !
                                  Neil
