    Document corrupts and artwork disappears (Windows 10 Pro with latest updates)
    5 Posts 3 Posters 5.9k Views 2 Watching
    • W Offline
      William Kansepa
      I was working on a design, closed the document and shutdown VS. Reopened the file and there's just a blank white space with no artwork, no artboard, no canvas. Also no layers, no links.
      Refer to the attached image:
      Also note that the Document Setup has changed from CMYK to RGB. But on document tab it's indicating as CMYK.
      Refer to attachment: 0_1662456679194_Document Setup.png
        b77 @William Kansepa
        @William-Kansepa Is the file size 0 Kb? If not, send it to the developer.
        Also: do you remember what was the last action before closing the file?
        W 2 Replies Last reply Reply Quote 0
        • W Offline
          William Kansepa @b77
          @b77 Thank you. I have emailed the file to @Vectorstyler
          • W Offline
            @b77 said in Document corrupts and artwork disappears (Windows 10 Pro with latest updates):
            1. I had restored the opacity on one of the layers to 100%.
            2. Added a dropshadow onto one of the brushstrokes
              VectorStyler @William Kansepa
              @William-Kansepa Got the file, it does seem to be corrupted, and there might be something related also to mistakenly showing CMYK in the title area.
              I will try to figure out what is going on with it, and recover if possible.
              Meanwhile, I recommend doing a clean install of VS and removing all user data from C:\Users<user name>\NumericPath\VectorStyler1.0\
              Some local color configuration might cause this issue, but not sure yet what.
