Ungrouping changing the appearance of artwork
I have this complex illustration of a building made from lots and lots of objects and groups:
After ungrouping all, it looks like this:
It looks like Vectorstyler is either changing the stacking order of the ungrouped shapes, or is changing the colors.
This is how it looks in Illustrator after I ungrouped everything:
I've attached the Vectorstyler file.
0_1661709149965_sample.vstyler
I downloaded your file, opened it in VS and exported it as PDF.
And then loaded that PDF into Coreldraw and Affinity Designer and ungrouped it, both worked
But the curious thing is, I loaded the PDF exported from VS
into VS as a test as well and then it works with ungrouping
The VS file did not work with ungrouping.Win 10, VS 1.1.058
@tudor Can you also attach the original Illustrator file?
Sorry if my assumption of it being an Illustrator file is wrong...
@William-Kansepa It's probably exported from a CAD app.
@tudor The drawing contains groups using shape combine operations. These can be selected after 3 or 4 ungrouping steps.
Use Styles -> Expand Group first and then ungroup all.How many Ungroup steps were used in Illustrator?
Ungrouping groups with shape combine operations will have similar results in other apps (where this feature is available).
One thing that I could do here is to stop Ungroup All at groups having combine operators. I added this to the backlog.
I also tried the PDF export and then import thing. And since exporting to PDF flattens the shape combine operations, the ungroup all worked as expected after importing.
Undoing the ungroup crashes VS on macOS. First time I tried I got a never ending spinner (using control-z), second time using toolbar the undo button stays depressed and I have to restart VS.
No, second time it came to life again.
@Ingolf said in Ungrouping changing the appearance of artwork:
Replicated here also.
@William-Kansepa said in Ungrouping changing the appearance of artwork:
The original was an EPS file downloaded from Getty Images. Here is a sample:
https://www.dropbox.com/s/sr82epasubd7m0z/sample.ai?dl=0
@VectorStyler said in Ungrouping changing the appearance of artwork:
How many Ungroup steps were used in Illustrator?So VS treats a "compound shape" (as Illustrator calls it) like a group. That explains it. It is unusual though, because all other applications I use have different commands for breaking apart compound shapes.
@tudor Yes the Illustrator compound shapes are imported as groups (in the AI file format, they are groups).
