    Little indicator Sign "°" for Path Sketch Tool to know that a Shape is closed
    40 Posts 5 Posters 82.9k Views 4 Watching
      Subpath @b77
      thank you
      found it out In the meantime
      I know something similar from
      Corel Draws Sketch Mode
        Subpath @b77
        @b77 said in Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed:
        @Subpath Nothing against a 'close' indicator and snap radius either. 👍
        It's just that your first screen capture from Xara showed the indicator on the cursor, not on the shape where it should be IMO.
        thats also often a fault of Recordit, it doesnt show
        often the right positions of shapes
        will use my other Gif Recorder "Screen to Gif" more often
        (btw a really nice little Tool) but Win only
          b77 @Subpath
          @Subpath Oh… got it.
            From my playing around with the Path Sketch tool, I am wondering if it really needs an indicator to close - the closed path erases away and an open path creates a fill - usually I am just making sure the path overlaps itself on the side opposite the fill
              Subpath @Boldline
              @Boldline said in Little indicator Sign "+" for Path Sketch Tool to know that a Shape is closed:
              Did not know that way, interesting.
              So, much fuss about nothing ?
              In my trials, I had a cases where the Shape
              was still open, so I let my request as it is.
                Boldline @Subpath
                @Subpath that is what @VectorStyler explained in that old post I linked to in the other thread (unless I misunderstood)
                What has been your experience?
                Part of me would like it to create a fill shape if you start within the fill shape and go out and come back in and create a negative cut if you started outside the shape and went in and came back out. That would seem pretty straightforward to me, but there might be some better methods with the way it is now that I am missing and need to practice and ask more questions about
                  Subpath @Boldline
                  i was thinking the way you close the shape
                  and came to the conclusion that a Snap Radius
                  and Indicator is still a useful thing
                  I often don't really understand the functionality
                  of the Shape Sketch tool yet either.
                  Sometimes it cuts when I expect the opposite
                  and vice versa. Will test it a little longer.
                    So, after all the discussion, i am refining my request a bit.
                    (btw i found the discussion helpful)
                    I would like to say that this is in no way urgent.
                    If the idea that should be implemented.
                    Ultimately, it is only an idea that is also based on my personal
                    preferences. Which some may share and others may not.
                    My original request was some kind of sign that is displayed
                    when a shape drawn with the Path Sketch Tool is closed.
                    This could be a small circle. However I would find it better if
                    the circle only appears when I am in the area of the snap radius.
                    And not that that sign is displayed all the time,
                    like with the pencil tool.
                    A solution where you give some kind of adjustable snap radius
                    for these two tools could also be sufficient.
                    And maybe an adjustable snap radius would solve the problem
                    alone with open shapes without the need for an indicator.
                      Boldline @Subpath
                      @Subpath If the closed path in Path Sketch is primarily used to remove vector fills material - how would it help and not hinder to add that snap ability? The very nature of the tool seems to be quick edits and from what I've found, simple overlapping the path essentially closes the shape completely. It seems even faster than adding a way to snap to the end point to me. Just sharing my thoughts
                      S 2 Replies Last reply Reply Quote 0
                        Subpath @Boldline
                        will make a video
                        but will take a little time
                          Subpath @Boldline
                          It seems a little difficult to decide whether an indicator would be helpful or not.
                          Because we can't test the difference.
                          And it also depends on what kind of shapes you create.
                          @VectorStyler can also leave the request open, in my opion
                          and see if any other requests come along
                          here the video
                            VectorStyler @Subpath
                            @Subpath There are plenty of things to do for 1.2 already, lets return to this later.
                            S 2 Replies Last reply Reply Quote 2
                              Subpath @VectorStyler
                                @VectorStyler said in Little indicator Sign "°" for Path Sketch Tool to know that a Shape is closed:
                                No Problem, take your time
