    Separation preview?
    33 Posts 4 Posters 41.9k Views 3 Watching
      @b77 It's good to hear most of the things I am concerned about are already dealt with and exist.
      what I meant by replacing colors was that there was an easy way to select a color you want to change using the future separations panel. It's easy when the colors have a spot color already, but harder if there are unnamed RGB or unnamed cmyk colors listed. If there's an unidentified color listed in the separations panel, how would I be able to find it in the design (if the design is complex).
      Prefacing this by saying I have not been able to do enough in repeater myself to know, but having the ability to restrict the size and spacing of the halftones based on what is needed for a best result print would be ideal.
      "But if you want rich black (darkest black)… that's something else, involving the overprinting of multiple inks."
      ok I might have to look into this part more - what I would probably need to do is select all by spot color and switch the fill or stroke color to a spot color black set at 0,0,0,100k. I created a spot color black that I use for this purpose already - would this not suffice to be a rich opaque black? or are you sayig there's a darker black I could use - or the only way to go darker than that is to overprint?
      • DazmondoD Offline
        Dazmondo @b77
        @b77 said in Separation preview?:
        OK, but since you can generate the PDFs with the separations (Print to file), it means you can open each PDF, merge the shapes then run the Repeater on them, or on the bitmaps.
        For me, I can't get the print to file (pdf or ps) to work consistently, out of around 20 tries I managed to get separations to work twice and, one output as PDF (which failed to work again) and one as .ps (which failed to work again) and that's going through all combinations of PDF and postscript, it seems to go through the motions but doesn't create a file. and now switching off separations no longer includes spot colours on a composite pdf and only includes one trim mark bottom left - that's my patience shot for the day --- may re-visit in a week or so?
          b77 @Dazmondo
          @Dazmondo It might be that you didn't enable the Pantones to separate by clicking their buttons in the Print window > Color tab?
          Anyway, send the file to the developer if indeed it fails to generate the separation PDFs.
            VectorStyler @Dazmondo
            @Dazmondo said in Separation preview?:
            Send me an example where print to file did not work. I will try to replicate the problem.
            Please note that the printing options are stored in the file, so if you save the file after (attempting to) print, I will have the same print settings, which helps in replicating this issue.
            • DazmondoD Offline
              Dazmondo @VectorStyler
              @VectorStyler said in Separation preview?:
              Thank's
              Update: by going back to selecting the first PDF option in the Printer section of the print dialog I've manage to get a composite with spots to work again - and managed to get one sep (pantone Green C) to pdf but can't trick any others
              Link to doc: https://drive.google.com/file/d/1uAWislybOREy0BLBnABgeUA2vcvQZP6O/view?usp=sharing
                @Dazmondo Looks like it gets confused by the file name given after the Print view is confirmed. This can be replicated here
                Try to avoid periods in the file name, then it should work.
                • DazmondoD Offline
                  So sending separations is working for you?
                  The periods where originally generated by VS inserting this: 'PEEEE.pdf.ps.pdf.ps.pdf.ps.pdf' which did generate a PDF but when I originally simplified the name to say P1585 to produce an orange sep PDF it didn't generate anything - I'm gonna have to step away from this for a bit and come back at a later date --- Thanks anyway
                    Yes I tested with the uploaded file. When printing, I enabled all color channels (with the icons in the first column) and I just gave a simple file name (test1.pdf).
                    I got 6 files with the name augmented by the color channel name.
                    • DazmondoD Offline
                      Wow that would be ideal - just can't trick it into producing a file - is it because I'm saving to desktop? 0_1658935747002_Screen Grab 2022-07-27 at 4.13.50 pm.png
                        @Dazmondo The first option "PDF File" should be working.
                        Try disabling "Background Printing" in preferences.
                        • DazmondoD Offline
                          Tried = no PDF produced so tried unticking seps = great composit PDF with spots intact (see grab) re-tick seps = no output???0_1658937203488_Screen Grab 2022-07-27 at 4.51.41 pm.png
                          Would you recommend switching background printing back on?
                            Yes, at least here it does not affect the output.
                            Can you make a recording of the whole thing (with Separate checked). Including the part where the folder and file name for the output is selected.
                            • DazmondoD Offline
                              Vid grab: https://drive.google.com/file/d/1L8GPvPbDlN7sHjvoy_joJTQaFpOX5lY3/view?usp=sharing
                              Note: The Test.pdf file on my desktop is a composite which produce great - also doing a find for TestA.pdf (the seps pdf produced in the vid grab) finds no match
                              Thanks
                                @Dazmondo All looks correct in the recording. But! there could be another issue.
                                Do you have it through the App Store?
                                This might be a bug the way file names are generated by VS, and the Mac App Store sandboxing.
                                • DazmondoD Offline
                                  Yes boss -- Mac app store version
                                    @Dazmondo Then that is the issue.
                                      VectorStyler @VectorStyler
                                      @VectorStyler You should have a new email with a license for regular VS. If you are willing to try, this one is notarized (Apple) but not sandboxed.
                                      • DazmondoD Offline
                                        Wow you really are a true genius --- 7 separation PDFs produced, now working great👍 👍 👍 0_1658940832084_Screen Grab 2022-07-27 at 5.49.58 pm.png
                                          Boldline @Dazmondo
                                          @Dazmondo Amazing! Awesome job persevering and sticking in there with it all. I want to echo his compliments to you @VectorStyler - you are indeed a genius. I'm impressed so often by what you figure out and solve and how quickly you make it happen
