I do not see any difference between the marked objects , and the others that are placed in this zone
I have a problem with recognizing which objects are selected in situations like below, and need to change it . Could you tell me the right name of Interaction Indicator? I can not find the right one.
@encart it should be using the layer color to show a thin outline around the selected objects. The background may cause this to be invisible.
@encart You can enable 'Show Nodes of Selected Shapes' in Preferences > Editing Options 2.
(A setting that I think should be on by default, btw).
https://recordit.co/MAJdm3N6cp
Selection appear only when I zoom out.@b77
Thanks! That may be useful.
@encart said in I do not see any difference between the marked objects , and the others that are placed in this zone:
Selection appear only when I zoom out.There could be a problem here, I added this to the backlog.
