    After clicking once with text tool to create temporary highlighted text, pasted text should replace it
    12 Posts 3 Posters 10.0k Views 2 Watching
      I noticed this first when i was trying to pasted copied text into a text on a path temporary text selection, but it also has the same issue with regular highlighted filler text. When we click once with the text tool(whether on a path or normal text) it creates the temporary "Lorem Ipsum" text and highlights it automatically. If I already copied prior live text to memory, one would expect then hitting command-v would replace the highlighted "Lorem Ipsum" text with what is in memory - but it does not. instead it pastes it next to it.
      Could this be changed in a future release of VS?
      0_1655741531016_72281986-412b-480a-8401-cecd59bd5f08-BLD 2022-06-20 at 12.10.00.png
        @Boldline This looks like a bug. Here when I paste over the highlighted text with Command+V, the text is replaced.
        I will try to replicate this.
          @VectorStyler Restarting VS and using a fresh document did not fix it here. Could it be related to my custom preferences? @b77 are you able to replicate the issue on your mac?
            @Boldline Could be a preferences issue. Try pasting from the menu (not using the shortcut).
            When using the shortcut, pressing the Command+ key will temporarily activate the transform tool, and that may remove the highlight.
              @VectorStyler I tried using the menu instead of the keyboard shortcut this time. I clicked once with the text tool to get the highlighted "lorem itsum" and used the edit>paste. It appends the copied wording to the end of the "Lorem Itsum"
              I also tried "paste inside" and that did not work either....
                @Boldline Then some settings is the issue, as here (version 1.1.046) seems to work fine.
                  @VectorStyler I am using the newest build, (version 1.1.046) as well. I set the preferences back to the default and restarted VS and tried again with the pasting shortcut and also with the edit>paste and it worked correctly both ways.
                  I wish there was an automated way to automatically go through and test preferences to see where an issue is!
                    @Boldline said in After clicking once with text tool to create temporary highlighted text, pasted text should replace it:
                    I will need to figure out what causes this, as it looks like a bug.
                      @VectorStyler Do you want me to send my custom preferences file over to you again?
                        @Boldline and @VectorStyler This is what happens here: https://recordit.co/Uzqe8vW0Ln — the result is different when I copy the text object then the text itself.
                          VectorStyler @b77
                          @b77 said in After clicking once with text tool to create temporary highlighted text, pasted text should replace it:
                          Yes, copying the text or copying the object are different (by design).
                            b77 @VectorStyler
                            @VectorStyler OK, but indeed the highlighted text doesn't get replaced when pasting some other text.
