@vectoradmin said in Improved Navigator Panel Slider Bar and added Navigator Icon:
@Vector-Rock
Could you add the Option of Opening up the Navigator Panel by using a Double Click on the Navigator Icon ?
Yes, this can be added.
Is there a way you could make the Navigator Icon Larger ? Maybe about double the size.
I would keep the scrollbar sizes, maybe making the icon a bit larger in the available space.
Would it much trouble/feasable in making the Magnifying Glass Icons any larger?
Maybe slightly shorten horizontally the Slider Bar area and make the Magnifying Glass/Slider Bar "row" a little taller to accommodate the larger size icon buttons.
Will do so.
There seems some quite a bit of "lag" (latency?) between when you drag the slider bar and the box actually changing its size. It doesn't change size as you are dragging for a little while and then it kind of "jumps" and catches up. Do you think anything could be done to help that ?
I will have to check the root cause of this. Added to the backlog.
@vectoradmin,
I really appreciate you accommodating these additional requests for improvement and refinement.
This is a tool that is undoubtedly used heavily as a day-to-day staple, so it's important that it is not an eye stain to use and operates at a high level.
Regarding increasing the Size of the Navigator Icon: Just to clarify, I wasn't recommending any significant increasing in the Scrollbar size, just a small amount If necessary. I figured if you did that, combined with making the Icon the maximum size in the available space, you could get a reasonably larger size. I know you'll do the best you can on this.
Of course, it will take more "use time" to make sure there are not any bugs, but just to reiterate, you really have done a fabulous job on this feature so far.
