problem with the top numeric corner field
With two selected nodes there's a problem with the top numeric corner field: When tapping up- or down-arrow the value increase only. No decrease when applying dwn-arrow.
The corner panel works fine though ...
@Raaskot said in problem with the top numeric corner field:
Is this from the keyboard? It seems to be working here.
what is the keyboard layout language selected for you? -
It is by using the keyboard arrows.
@VectorStyler said in problem with the top numeric corner field:
I also notice it works fine ie. on new primitive objects converted to shapes, but not always.
I've isolated a problematic example here:
corners.vstyler
