    update 1.3.006
    Scheduled Pinned Locked Moved Announcements and News
    4 Posts 4 Posters 761 Views 3 Watching
      VectorStyler 1.3.006 release notes
      • Improved precision in offset stroke stripe
      • Improved stroke rendering speed
      • Improved brush handling on complex shapes
      • Top down coordinates to align page grid to the page top left corner
      • Improved 16-bit BMP support
      • Improved magic wand tool
      • Added a palette panel menu command to expand spot colors of selected objects
      • Show scaled font sizes in the Character panel when selecting text inside scaled groups
      • Detach clones before ungrouping the clone source
      • Allow custom shaped corners when one corner side size is set to zero
      • Shift+Click should deselect single object selections
      • Added an option to the style picker tool to select objects or groups
      • Shape conversion should keep object position
      • Return to normal object selection after exiting the text editor
      • Initial line to be shown correctly in the polygon selection tool
      • Fixed a regression in the font manager view
      • Fixed a regression in creating color presets
      • Fixed a preview issue in the modal contour view
      • Fixed a bug causing objects to be selected multiple times
      • Fixed a bug in distorting 16-bit RGB images
      • Fixed a bug in selecting color for the paragraph bullet symbols
      • Fixed a bug in selecting symmetric randomization in the Move command
      • Fixed a bug in extending paths with the line tool inside transformed layers
      • Fixed a bug in undoing multiple repeater expansions
      • Fixed a bug in changing selection while using the Anchor tool
      • Fixed a bug in working with large number of objects in the Appearance panel
      • Fixed a bug in handling unit names in math expressions
      • Fixed a bug in the Simplify Path command with Node selections
      • Fixed a bug in adding stroke to selected text from the Stroke panel
      • Fixed a bug in handling vector brushes
      • Fixed a bug in expanding vector brushes on small shapes
      • Fixed a bug in selecting shape presets for the Bend effect
      • Fixed a bug in using the Style Picker tool after the Node tool
      • Fixed a bug in placing cloned objects outside of layers
      debraspicherD BoldlineB 2 Replies Last reply Reply Quote 15
      • debraspicherD Offline
        debraspicher @VectorStyler
        @VectorStyler Thanks for fixing the cloned object bug
        32GB RAM @ 6000MHz
        PNY NVIDIA RTX 5070 Ti 16GB; Display 1: 4K @150%; Display 2: 4K @150%
        • E Offline
          EricP
          @VectorStyler thank yo for this quality update with lots of fixes
            @VectorStyler Impressive list of improvements! Thank you for your continuous efforts to improve VS. version 1.3 gets better all the time
