    VectorStyler 1.3.002
    Scheduled Pinned Locked Moved Announcements and News
    6 Posts 6 Posters 950 Views 5 Watching
      VectorStyler 1.3.002 release notes
      • Added a separate Fonts panel
      • Added preset and style saving options to Mirror, Transform and Align to Path groups
      • Bezigon tool to close the path when clicking on the starting node
      • Transform Each in Transform - Move should work in Randomized mode only
      • Automatic positioning of halftone effects above fills and below strokes
      • Allow interactive repeater, halftone, and mirror tools to create these effects
      • Allow repeater preview in the create new action
      • Improved node handling in swirling lines shape
      • Allow snapping in complex documents (still subject to limits)
      • Stroke Width panel to edit distance instead of width for offset and contour effects
      • Node eraser tool to work with open path endings also
      • Expand stroke should expand some content effects first
      • Improved Select Inside handling for double click (enabled in Settings)
      • Use current language if possible for font names
      • Improved pattern brush handling and brush expansion
      • Allow contour effects inside Mirror, Transform and Align to Path groups
      • Improved DXF importing
      • Improved Bezigon tool
      • Improved handling of blended shapes in halftones
      • Copy and Paste of object size is a customizable action
      • Tiling patterns to allow larger tile count, with a solid color preview
      • Improved handling of corners in shapes with smooth nodes
      • Added hyphenation dictionaries
      • Keep default document unit from last selection
      • Improved Intertwine effect handling when scaling
      • Improved popover panel opening on scaled screens
      • Fixed the modal Halftone view layout
      • Fixed a regression in using Adjust Profile with Masks in the Stroke Width panel
      • Fixed issues with non-translated UI texts
      • Fixed a bug in expanding Align to Path groups
      • Fixed a bug in the path simplifier tool
      • Fixed a regression in the Source option of the path brush tool
      • Fixed a regression in creating nodes on paths
      • Fixed a bug in the offset path effect of open paths with overlapping ending nodes
      • Fixed a bug in the Extract Path section tool
      • Fixed a bug in opacity handling of Block style Drop Shadow effects
      • Fixed a bug in expanding Drop Shadow effects
      • Fixed a bug Flatten Opacities action
      • Fixed a bug when using symbols in blend effects
      • Fixed a bug in converting underlined text to curves
      • Fixed a bug in Expand Clipped Group for hierarchical clipping
      • Fixed a bug in the Magic Wand tool Thinness option
      • Fixed a bug in handling circular repeaters without shape
      • Fixed a bug in creating large offsets of small shapes
      S 1 Reply Last reply Reply Quote 11
      • C Online
        Comet
        Thanks for the speedy update! I'm new to this program but am blown away by how powerful it is. Still learning the ropes.
          Subpath @VectorStyler
          wow, thats a very impressive list
            Wow, an impressive list of fixes and updates! Thank you for your continued dedication to improving VS by leaps and bounds. It's my favorite application to use
            • E Offline
              EricP
              @VectorStyler wow, super impressive update after the massive 1.3 release !!
              Thank you so much for your dedication to quality and usability. That makes a whole difference
              • IngolfI Offline
                Ingolf
                Splendid update. And the biggest third-decimal update I’ve ever seen - without any competition. 🙂
                🍏 macOS Sequoia Apple Silicon
