update 1.2.087
VectorStyler 1.2.087 release notes
- Artboard name to be shown outside of the bleed area
- Improved spiral shape with low decay
- Fixed an error in deleting actions in the Recent Actions panel
- Fixed a regression with copying objects with mouse right click
- Path eraser brush size should be fixed
- Show snapping indicator for restricted moving
- Fixed a regression in the corner editor tool
- Stroke width should be selected for text frame, not for the text inside
- Fixed a regression in selecting fonts without a text selection
- Paste above and below should keep original object position
- Do not allow ungroup inside symbol references.
- Fixed a bug in using the Preview button in Object Options
- Keep symbol position when switching symbols in an object
- Fixed a bug in positioning symbols when exporting to PDF with Named Groups option
- Inner shadow effect opacity should work with Normal composition also
- Fixed a regression in export slice scaling
Just a small surprise.
When I installed the latest update and started VS for the first time,
the VS theme was set to "Standard Light" without my knowledge.
My normal setting is "Standard Dark."Another small thing.
I also noticed that right-click copying works a little differently now.
Unlike before, a copy is no longer placed on the canvas as soon as
you right-click, but only after you release the left mouse button.I just wanted to mention it, and I don't mind if it makes right-click
copying work better.
@Subpath said in update 1.2.087:
yes, this will be the default theme. If you did not change the theme before, then you see the default, can be changed in the settings.
I've been using the "Standard dark" theme for a very, very long time.
And no previous update has switched it to "Standard light" during installation.
So this was the very first time VS has done that.By the way, the right-click function now works as usual. I don't know
what the reason for the different behavior was before.
@Subpath I had the same experience today when I installed VS. I was going to post something about it on here but you beat me to it. I understand now that I was always using the default mode apparently and so when the default switched, my setup also switched. I love that there are so many customizations available for the UI to suit anyone's taste and preferred use
Of course, I also love having the choice between different
settings. But when things start acting on their own and changing
familiar settings without my intending them to, I do frown a bit.Why wasn't something that doesn't work now a problem before?
It's always a bit difficult to understand.
Thank you
I've already switched to version 1.2.088.
I didn't notice the fix because my beloved dark theme was still there as usual.
But I'm sure I would have noticed it if it had been the light theme.
