Copying Objects in VectorStyler with the Right Mouse Button
  • I think every VectorStyler user knows that you can copy
    objects by holding down the Alt key. But did you know that
    you can also copy objects in VS with the right mouse button?
    Try this:
    Select an object with the left mouse button.
    Hold the button and press the right mouse button once.
    A small icon and a plus sign will appear.
    Hold the left mouse button and move the object, and
    you'll see you've created a copy of the object.
    Copying multiple objects works a little differently.
    Select all the objects you want to copy, hold down the
    left mouse button, and move the selected objects slightly.
    Don't worry, the copy will appear at the original point.
    While still holding down the left mouse button press
    the right mouse button once to create the copy.
    If you want to create multiple copies, place your objects
    where you like to have them and release just the left mouse button once
    your objects will stay selected
    take your objects again with the left mouse button move them
    a bit and press the right mouse button once.
    Here a video
