My mini wishlist
My mini VS wishlist:
list item.tif file format export. At present VS only has the .tiff option.
list itemImproved text on path functionality (check Illustrator's or Affinity's. I love it how I can also easily adjust the size, position, offset, baseline and kerning of the text using shortkeys. For instance, notice how you can smoothly add text to the top and/or the bottom of a path/shape in these two applications).
list itemImproved Text Tool sensitivity:
Often times this tool will pick up a shortkey for another tool if the initially character of what you want to type is similar to the assigned shortkey. Eg you want to type the word 'Looming', the Text Tool will convert to the Path Sketch tool (shortkey L).
Also when you double-click text with the Transform Selection tool, you will occasionally end up in the Isolation Mode.
@William-Kansepa said in My mini wishlist:
I will add these to the backlog.
Is this basically a file name extension issue?
@VectorStyler said in My mini wishlist:
Yes it is. Thank you.
Interesting.
Quoting directly from the TIFF 6.0 file format reference:
The recommended MS-DOS, UNIX, and OS/2 file extension for TIFF files is “.TIF”.
