Using templates?
  • I create a document, set up the guidelines, and use the "Mark as Template" option from the File menu. Then I save the empty document in a new folder called "templates".
    When I now want to create a new document with "New from Template", I see my "templates" folder with the template document I chose.
    After I have edited my document and want to save it with "Safe As", I get the "templates" folder as the save location selected again and have to change the save location manually. Why is the templates folder displayed?
    @creative said in Using templates?:
    I think it is because that is where the new file was "created from". I will find a solution for this.
  • The last destination ist displayed. If the document is saved to a folder "my documents" next time using "New from Template" isn't showing the "templates folder" to chose a template but the last used folder "my documents".
