    Kind of Shape Library
    16 Posts 5 Posters 13.5k Views 4 Watching
    • S Online
      Subpath
      VS certainly has the ability to save shapes. But it's not really what
      I would imagine it to be.
      These are just my thoughs about something like that and i let all in the Hand
      of VS and what he like to take from that. My respect for him and my love
      for his App, will, of course, not be dimished.
      So here my thoughs:
      A panel that is only used as a Shape Library,
      so that a user only calls just that Panel.
      To call that Library maybe add a Icon in the Tool Box
      where Smart Shapes already are.
      Ideally, it should take only one click to store a shape
      and one click to place a shape on the Canvas.
      ( But less clicks as possible )
      Drag and drop should als be possible.
      Saving a new shape.
      On the one hand, it could be done with automatic naming.
      If and when the name is the same, a counting number could
      be automatically placed after the name.
      So that even lazy guys like me, would like to use the library.
      A kind of batch feature would be nice so you could easely
      add a bunch of shapes into the library
      I also think it may be helpful if a user could select
      a bunch of shapes from the canvas and put it in the Library.
      And also select a bunch of shapes in the Library to put it
      onto the canvas ideally side by side and not one of another
      Anyone who has better ideas or additional thoughts is welcome to share it.
      Objections, of course, are equally welcome. 🙂
      VectorStylerV 1 Reply Last reply Reply Quote 6
      • S Online
        Subpath
        I add here the way how it works by now to store Shapes in VS
        Lets take a look:
        At first glance i dont see anything that looks like a Shape Library.
        By looking in Manual a User may note that you can save Shape
        presets in the Presets panel.
        So lets take a look in the Presets Panel.
        We call the Presets Panel via
        Menu > Panels > Presets > Presets
        or per Shortcut Alt + Ctrl + T (Win)
        Then i open the Shape Presets clicking on
        the Name/Title does nothing you are forced
        to use the little Arrow Sign on the Left
        A single click onto a Shape does nothing
        A double click on a Shape does nothing
        drag and drop does nothing, as it is by now
        After reading the Manul you notice Shape presets
        is only helpful/useful if you like to replace a Shape
        on the Canvas
        While this may useful in some cases, it is not
        what i expect from a Shape Library.
        Lets look on how to create a Shape, store it
        in the Shape Presets.
        While the Shape Presets Panel is open
        i select a Shape on the Canvas press the "+" Sign
        on the right.
        a Menu appears > select "Create a Shape"
        a little Box appears, where you could choose
        a Group, a Name and a description
        if a Name already exist you will be asked
        if you will overwrite the Shape with the same Name
        or choose another Name
        confirm with Enter and the Shape will be stored
        All this is fine, but not really fluid.
          VectorStyler @Subpath
          @Subpath said in Kind of Shape Library:
          Would these shapes have names. The idea with shape presets is that they can be accessed from all sorts of places (effect properties, etc), but that only works if they also have a name.
          • S Online
            Subpath @VectorStyler
            I mentioned in point 4 that maybe you could perhaps
            do automatic naming. Because giving Names manually
            slows the Workflow and its tedious with many Shapes.
            If automatic names are not possible or makes no sense.
            Then i thinking more along the lines of simple shape storage
            with this library. Which could perhaps also be without a name.
            Because how often does a user create a Shape that is used again
            later and without a library he has to create it again each time.
            But as i mentioned I leave it up to you to decide what suits your concepts better.
            If you have further questions, i am happy to answer
            Victor VectorV 1 Reply Last reply Reply Quote 1
            • Victor VectorV Offline
              Victor Vector @Subpath
              @Subpath
              I understand what you are suggesting and I think you have some good points. Much could be done to make the Preset panel more functional and efficient. I think dragging and dropping would be a good start, although let's say you had a dashed stroke with arrows on both ends. I don't know how a drag and drop would distinguish which item to store. Perhaps a pop-up with check boxes to select your choices? Would they have naming fields beside each check box?
              I see many some similarities to Affinity Designer's "Assets" Panel. Would that be a good reference to start?
              • S Online
                Subpath @Victor Vector
                @Victor-Vector
                My idea looks somewhat similar to Shape Presets but differs
                from the Shape presets. Which is why I suggested creating a
                separate panel for that Library.
                With the Shape presets you can only replace one Shape with another
                and to do this a shape must be selected on the canvas.
                Which is not my Intention.
                My idea can be thought of more like a very large clipboard storage.
                In which you can store/save created shapes/forms in order to bring
                them back onto the canvas if you want them.
                The whole thing is intended to prevent a form from having to be created
                again and again. Or have specific shapes ready, for example for architecture
                or other areas.
                In the meantime, I thought about my idea again and will post my thoughts
                here then.
                ...I see many some similarities to Affinity Designer's "Assets" Panel...
                I see that similarities too and I think it's the closest to that idea.
                Victor VectorV 1 Reply Last reply Reply Quote 0
                  @Subpath
                  Your additional thoughts helped to add clarity. Thank you for that.
                  So to extend the Affinity Assets Panel example, the same could be said for Styles as well. Having a way to easily add Shapes (assets) from a panel to the artboard/canvas as well as being able to add them in bulk into the assets panel would be very handy, especially if there were auto-names like "asset0000", "asset0001", etc. User can of course rename them after.
                  So I was thinking about the difference between a shape and a preset and I came up with a quick visual diagram to help my understanding of the type of things the shape (asset?) panel would incorporate. Please, good community, edit and critique this idea as it is not fully formed, just a starting point to this conversation:
                  Know that I didn't include all of them, just a few examples, however it seems like there are few things that fit under shapes. I threw glyphs in there, thinking about shapes that were categorized as a typeface (a custom shape that could be inserted into a text element, but not an entire font on it's own). Font file glyphs would of course be accessible from the Glyphs Panel.
                  I attached the .vstyler file below in case anyone wants to edit or reform the Venn diagram quickly for discussion, without having to take the time to create it from scratch: 😛 🤓
                  Shape Venn Diagram 00.vstyler
                  Also here is a screen-grab list of preset categories to help the conversation:
                  VectorStylerV 1 Reply Last reply Reply Quote 3
                    VectorStyler @Victor Vector
                    Just a small note on style vs presets:
                    Most of these attributes can be saved both as presets or as styles.
                    The main difference between styles and presets is that styles are always kept in the document and always linked, so when a style content changes all its uses are updated.
                    Presets can be saved outside of the document, and always selected by value (not linked), so if a preset changes, its uses are not updated.
                    Victor VectorV 1 Reply Last reply Reply Quote 3
                      Victor Vector @VectorStyler
                      Those three sentences reveal a ton on how VS works regarding the difference between these elements. Thanks for that!
                        @Victor-Vector I'm glad you brought this topic up and created the venn diagram. To me, presets and styles being intermixed in the VS user interface is a little overwhelming and confusing to me. It's hard to wrap my head around them because there's nothing tangible about either in the way I see them.
                        I'm not an expert on how this should all be organized, but I believe it would be less confusing if the presets and styles were completely separate from one another, not listed together in the same section. Maybe a presets folder and styles is a secondary folder inside? Just thoughts
                        0_1705430636113_430b4aef-d3c1-43fa-800f-bf3afb5fc4b6-BLD 2024-01-16 at 13.43.45.png
                          Victor Vector @Boldline
                          @Boldline I agree, it was/is confusing to me too, and while I get that Styles and Shapes are kind of like a subset of presets, they beg to have their own place where they are easily accessed, like @Subpath's clipboard analogy.
                          Based on the idea that "if a style is updated it all its uses are updated", am I wrong in thinking that a Shape that is a "Style" is actually a "Symbol"?
                          If so, this is exciting, from a purely geeky organizational way, because it means these things could potentially be organized and implemented in a very elegant format, providing the user understands how each element is defined.
                          • S Online
                            Subpath
                            Finally,
                            I came to the conclusion that “Assets” in
                            Affinity Designer was the closest thing to my idea.
                            I refine my points, according on that, here:
                            The Video here is how "Assets" is working
                            in Affinity Designer 1. Still have a copy of it.
                            Here the Video
                            So here my refinded thoughts:
                            Possible Content for this kind of Asset Panel
                            could be Shapes, open Curves, Textlines.
                            ( will call it here just Shapes )
                            Just like Affinity Designers Asset Panel.
                            maybe where Smart Shapes already are.
                            I also think it may be helpful too if a user could select
                            4b
                            Saving a new shape.
                            add a bunch of shapes into the library. Or just import
                            all selected Shapes from a Folder
                            • F Offline
                              FastVector
                              Just a question. In the assest panel in AD you have complete illustrations. And in Vectorstyler as for I know you can only save a separate shape as preset. So how do you see this? (personally I would like to see and save complete illustrations).
                              Windows 10 | 1920x1080 | 125%
                              • S Online
                                Subpath @FastVector
                                @FastVector said in Kind of Shape Library:
                                Do not mind. I think the video makes this clearer.
                                There I show that you can also save groups of objects in the Assets panel
                                By the way, you are very welcome to add your own wishes/Ideas here.
                                  Boldline @Subpath
                                  @Subpath @FastVector I would welcome an Asset Manager" much like what Affinity Designer provides. In my copy of Affinity Designer 2, it was easy to add halftones and splatters and the like to the Asset Library and then open them and pull them out at will and drag them onto the document.
                                  Here is an video example of how easy it is to drag the assets into an Affinity Designer file
                                  0_1705697051646_041919ea-99b7-4565-b5b9-78cb10e4c7fd-BLD 2024-01-19 at 15.43.58.png
                                  • S Online
                                    Subpath @Boldline
                                    @Boldline
                                    Thanks for the video. Think it's the same as in Affinity Designer 1.
                                    But while it's easy to drag and drop designs from the panel onto the canvas,
                                    it's not possible to drag and drop designs into the assets panel.
                                    Which would be one of my wishes for something like this in Vectorstyler.
