sample colors from document for fill and stroke in context bar
The fill and stroke panels in the context bar are great for quick views of what is going on in the file. I think the rectangles could be more like squares, making more room./
My main thought was being able to easily sample a color from the artboard using the eyedropper tool, or dragging the stroke or color fill box to the color you wanted in the document
@Boldline You can sample a color from the artboard and from around the artboard if you use Shift with the eyedropper (shortcut: I).
I guess the swatches are wide for when you have gradients and patterns — I don't want to see them too small/compressed.
@b77 thanks. That is good. I think I was trying to find a way to make the fill color in the artboard become the stroke color. I see that it works if I am using a color that is already a fill or stroke and I am wanting to change to that color in the same manner.
Good point about the patterns and fills. I cans ee why the wider panels for colors would be helpful
@Boldline If you want to pick a color for the stroke of the object, first press X to switch the color button in the Color panel from Fill to Stroke, then picking a color with the eyedropper will assign it to the stroke.
@Boldline There is a color sampling button now in the Color Panel.
