    Preserving and migrating settings across major updates (and risks of importing .settings / .vstool files)
    9 Posts 4 Posters 42 Views 3 Watching
    • 861475_VctSt8 Offline
      861475_VctSt
      When updating from 1.3.xxx to 1.4.001, I encountered a series of baffling issues that I had never experienced before. On the surface, print-related markers (such as printer marks) stopped displaying, and 100% Black (K100) began appearing like rich black.
      To resolve this, I completely removed all VectorStyler-related data and performed a clean installation. Afterward, to restore my workspace, I tried the following methods separately as independent approaches:
      • Importing previously exported configuration files (such as .settings, .vstool, and .vswork).
      • Restoring data from a backup of my Application Support folder.
      However, neither method solved the issue—likely because the backups themselves already contained corrupted or incompatible resources. In the process of troubleshooting, I even reached a point where I could no longer switch the UI language to Japanese.
      With no other options left, I ended up rebuilding all my preferences and tool setups manually from scratch on a clean installation. Since this process is quite time-consuming, I would like to avoid having to repeat it in the future.
      To prevent this kind of situation going forward, could you advise on the following?
      1. Best practices for updates: What is the safest procedure before or after an update to prevent settings corruption or resource conflicts?
      2. Compatibility of exported files: Is it risky to import .settings, .vstool, or .vswork files across major version updates? Specifically, when an update changes the menu structure, icon sets, or internal specifications, can loading older configuration files directly cause regressions or UI glitches?
      LIc. 0 OS10.15.8
      LIc. 1 OS15.8.3
      VectorStylerV M 2 Replies Last reply Reply Quote 2
        VectorStyler @861475_VctSt
        @861475_VctSt said in Preserving and migrating settings across major updates (and risks of importing .settings / .vstool files):
        Copying the files in the /resources and /presets folder should work, but there might be some error I'm unaware off.
        One thing to try is to copy first the /presets folder. This is needed to keep all changes to global presets.
        Then in the /resources folder copy the settings.xml file only.
        .settings should be compatible, but .vstool and .vswork will not contain the new tools and menus.
        There is no safe way to transfer any tool, menu or shortcut customizations without hiding the new features.
        If you still have the 1.3 files from then /data folder, can you send them by email to me. I would like to replicate the same environment here.
        861475_VctSt8 BoldlineB 2 Replies Last reply Reply Quote 0
          861475_VctSt @VectorStyler
          I have resolved the issue myself.
          I have sent the data via email for your reference.
          LIc. 0 OS10.15.8
          LIc. 1 OS15.8.3
            @VectorStyler Could VectorStyler offer a Migrate Workspace and Settings option when upgrading to a new major version?
            I’ve spent time arranging my panels, customizing my toolboxes and shortcuts, and saving my preferences in a named settings preset. When I upgrade, I’d like to bring that setup with me. This would include both the workspace I’m using and the custom .settings preset, so I can keep using and switching back to that preset after the update.
            Ideally, VectorStyler would detect the previous version’s workspace and settings preset, migrate compatible copies, and open with them active. If a specific preference, shortcut, or workspace item can’t be carried over, it could tell me which one needs attention. Keeping the original files intact would also give me a way back to my previous setup.
            Could this be built into the upgrade process so that a major update doesn’t mean rebuilding my working environment by hand?
            861475_VctSt8 1 Reply Last reply Reply Quote 2
              861475_VctSt @Boldline
              Thank you for your comment. I completely agree with you.
              As things stand, whether we unknowingly keep backing up corrupted resource data or try to apply older configuration files to a new version with updated specifications, there is still no foolproof way to reliably carry over our customizations.
              It would really be great to have some kind of safeguard or mechanism in place so we can update with peace of mind.
              Thinking about the effort required to rebuild everything from scratch again, I also find myself feeling hesitant to invest in detailed customizations for VectorStyler right now.
              LIc. 0 OS10.15.8
              LIc. 1 OS15.8.3
                monsterfox @861475_VctSt
                @861475_VctSt My workflow may be different from yours. I usually save a lot of files: settings, keyboard shortcuts, swatches, presets. These four files mean updates won’t affect me much. The only thing that might change is the layout, and that can also be saved as a workspace file. I just haven’t saved one yet.
                861475_VctSt8 1 Reply Last reply Reply Quote 1
                  861475_VctSt @monsterfox
                  @monsterfox
                  Thank you for your reply.
                  It seems that is indeed the safest way to maintain our setups that we have available right now.
                  As you pointed out, we really need to be careful about this.
                  (Copying the files in the /resources and /presets folder should work, but there might be some error I'm unaware off.)
                  Actually, I have been managing my setup this exact way ever since the VectorStyler beta days. However, this time I could not properly restore my environment from either those saved configuration files or my resource data backups. Because of that, I had no choice but to rebuild all my customizations from scratch again.
                  By the way, how do you usually update VectorStyler? Do you update directly through the in-app menu, or do you download the installer manually so you can keep the older version?
                  Since I always want to keep the previous version on hand just in case something goes wrong, I almost always take the latter approach.
                  LIc. 0 OS10.15.8
                  LIc. 1 OS15.8.3
                  M BoldlineB 2 Replies Last reply Reply Quote 1
                    @861475_VctSt I installed it manually, overwriting the previous files. When I installed 1.4, I created a new folder, but I didn’t realize that 1.4 builds on 1.3, so my old 1.3 files are gone too.
                      Boldline @861475_VctSt
                      @861475_VctSt I have a dedicated folder on my computer where I store my custom workspace and custom settings files. When big updates happen, I just go in and re-link them. It has not been an issue for me personally. Then again, I'm updating directly through the in-app menu and not trying to keep the older version.
