    Cannot activate rotate option when hovering
    11 Posts 4 Posters 34 Views 3 Watching
      VectorStyler @Raaskot
      @Raaskot Send me that file.
      RaaskotR 1 Reply Last reply Reply Quote 0
      • RaaskotR Offline
        Raaskot @VectorStyler
        dont-activate-rotate.vstyler
          @Raaskot Seems to be working here: https://cleanshot.com/share/wVfRBhQ5
          Could be a settings / workspace issue (I always test with the defaults).
            Boldline @Raaskot
            @Raaskot works over here for me (I'm using a custom settings file). Sometimes it helps to save and close out the file and try again, and then try restarting VS completely if reopening the file itself does not fix it. Then checking if it works with default settings. If it works with default settings, send the developer your custom setting file because the issue is probably in there.
            RaaskotR 1 Reply Last reply Reply Quote 1
            • RaaskotR Offline
              Raaskot @Boldline
              No, no rotate-option available upon Presets Default restore (image) and VS restart. I wonder what the asterisk (x) tell?
                @Raaskot Then [*] means that something is changed in the settings from the defaults
                • RaaskotR Offline
                  Is it releated to issue?
                  Rotate handles is still missing after restart/reset.
                    monsterfox @Raaskot
                    @Raaskot The asterisk * indicates that a parameter has been modified and no longer matches the default value. My workflow is to configure all parameters, save them as a file to disk, and load the file when needed.
                    • RaaskotR Offline
                      Raaskot @monsterfox
                      @monsterfox
                      I understand ...
                      "My workflow is to configure all parameters, save them
                      as a file to disk, and load the file when needed".
                      ... but that doesn't solve the issue with the missing rotate handle in UI since last update, am I right?
                        monsterfox @Raaskot
                        @Raaskot I have tested your file, and the rotation handles work fine on my end. The issue is likely with your workspace file. Send your workspace file and settings configuration file to the developer, and they will fix the problem based on your case.
