    60 Posts 4 Posters 3.5k Views 3 Watching
      VectorStyler @monsterfox
      When importing images in FreeHand 9, the current imported‑image filename can be viewed in the bottom info bar. VectorStyler does not have this feature. Could you please add this capability? Thank you.
      It show the file name, that is the "400" text, and attaches the DPI info.
        monsterfox @VectorStyler
        @VectorStyler Please check the video. In FreeHand 9, the filename is displayed when importing, before you click on the canvas. VectorStyler does not support this yet. When importing multiple files, it would be much more convenient if there was text showing the name of the currently imported image.
          @monsterfox This can be done only after the image was imported
            Could the menu operations also be made into pop-up panels like the toolbar? For certain special operations, there would be no need to keep clicking through the main menu repeatedly. We could directly access the submenus for more convenient workflow.
              @monsterfox This should be doable with Customize Toolboxes.
              There is a [+] icon next to the Toolbox dropdown, this can be used to create new toolboxes.
              M S 2 Replies Last reply Reply Quote 0
                @VectorStyler I understand that. Normally, I create new toolboxes for my frequently‑used tools. But sometimes I need to repeatedly use certain menu functions that are not everyday tools, so it would be unnecessary to make a dedicated toolbox for them. A temporary solution for this would be sufficient.
                  Subpath @VectorStyler
                  In my opinion, the toolboxes in Vectorstyler would be
                  somewhat more useful if they were more flexibly adjustable in size.
                  Made a Video here how it works in Coreldraw
                    VectorStyler @Subpath
                    @Subpath said in Detail Optimizations for Version 1.3:
                    I will add this to the features list
                    M 2 Replies Last reply Reply Quote 1
                      @VectorStyler https://youtu.be/Cw55FX62hBY
                      Can a feature be added, referencing the VectorCraft program shown in the video? When the pointer selects a canvas, the currently selected canvas gets a black border to indicate selection. This would make the effect more intuitive. Thank you.
                        @VectorStyler https://github.com/storytold/vectorcraft
                        This is the project address of the open-source software VectorCraft. The path simplification feature in VS is still not very usable at present. Please refer to their code and improve the equivalent feature in VS.Thank you.
                        https://youtu.be/wYwcrMxgD8U
                        VectorStylerV F 2 Replies Last reply Reply Quote 1
                          @monsterfox Can you send me the file with that shape (before simplification) so I can test it here also? Thanks!
                            @VectorStyler 未命名-2.vstyler
                              @monsterfox I tested with this example, but it is not clear where the simplification is broken in VS.
                              Can you post an example simplified in VS and one in VectorCraft (possibly with similar simplification parameters).
                                @VectorStyler https://youtu.be/3cWf5XqSvDY
                                Pay attention to the areas marked with arrows where I operated in the middle. With VectorCraft, the operation preserves the shape of that section, and the overall simplification stays close to the original lines. However, the same operation in VS produces two issues:1.The shape at the arrow-marked section distorts during simplification.2.Even though I keep dragging the slider steadily during simplification, critical parts flicker constantly — appearing intact one moment and missing the next.
                                Good simplification should only reduce nodes without altering the shape. VectorCraft has just two parameters: Tolerance and Corner Point Angle Threshold. This covers nearly all my workflow scenarios, and its default slider settings work great. Parameter tuning is only for adjusting node details based on personal needs. VS has two setting functions, neither of which works well.
                                  @VectorStyler https://youtu.be/Ji7Z2vzEiNE
                                  When using the Width Edit tool, regardless of the current color of the path, the panel defaults to white fill and transparent stroke. It would be more convenient if the initial settings inherited the fill and stroke style of the original shape.
                                    I will try to fix this
                                      @VectorStyler https://youtu.be/G-L0nknAQEY
                                      When adjusting the number of sides with the polygon tool, the polygon rotates as the side count changes and is never horizontal. Could this behavior be changed so the polygon stays level at all times? Also, if possible, please add a control handle on selected polygons to adjust the side count more conveniently. Thank you.
                                        @monsterfox By default, a polygon at 0 angle has its first corner on the X axis. Increasing the sides and not changing the angle will keep this corner at 0 angle.
                                        Unfortunately, this cannot be changed now (would mean a different interpretation of polygon parameters).
                                          @VectorStyler Could you please add this feature first: keep the selection bounding box visible when an object is hidden. Also add an option in the settings to hide this selection bounding box. Thank you.
                                            fde101 Global Moderator @monsterfox
                                            Please be VERY careful around the VectorCraft (and related) application code right now. That project was large-scale ML-generated with specific parameters to rip off the Adobe user interface. There are suspicions that it likely violates Adobe design patents (among other things) and the manner in which the code was generated falls into a gray area of emerging legal doctrine which might be considered unethical even if it is not illegal depending on factors that I don't think are entirely clear at this time.
                                            There might not be a legal issue with this, but I don't think anyone really knows that for sure right now, so play it safe...
