    Just a Pattern
    51 Posts 8 Posters 61.0k Views 8 Watching
      Subpath @marce
      @marce said in Just a Pattern:
      @Subpath "Forum says "you can upvote a user only six times per day",
      Very curious, didn't know that.
      But dont worry, if my post inspire people or
      are helpful then this is fine enough 🙂
        Created using:
        The colorize feature in the Repeater, which can also colorize strokes with a bitmap.
        (See Manual how)
        The Style Picker Feature, which allows you to transfer style attributes
        from one group of objects to another.
        You could take look at this Link
        https://www.vectorstyler.com/forum/topic/5851/a-style-picker-tool-feature-and-a-few-strokes
          I used a shape with a multi-colored gradient to colorize a bunch of strokes using the Repeater,
          and transferred the color (style)—using the new Style Picker Tool Feature— to a bunch of
          other Strokes created with the Blend function.
          The strokes colored with the Repeater
          Here the Result
          1 Reply Last reply Reply Quote 8
            Took a a gradient from another App with a screenshot and use
            this raster graphics then to colorize a bunch of strokes with the Repeater.
            This time no Style Picker Feature where used.
            I create a a color Palette instead from that bunch of strokes
            (create Palette from selected Objects)
            and colored a Swirling Lines Shape after converted it to curves
            via Colorize with that new palette
              Made in Vectorstyler, recreate a pattern i found on the Internet
              mine look a bit different but i am fine with that
              For anyone who is interested, you need to split the Line
              in different pieces to create this pattern
                I more or less replicated a pattern I found online.
                I couldn't resist using the "Along Stroke" feature
                in VectorStyler's gradient editor.
                  This was inspired by "string art"; I wanted to experiment with creating it
                  as vector graphics and applying gradients to the individual paths to see
                  what kind of patterns would emerge.
                  The String Art was made in Nodebox because its very easy to
                  create Point/Node Pattern with it.
                  https://www.vectorstyler.com/forum/topic/4119/a-kind-of-patternnodes-for-windows-free-win-mac
                  The coloring was created in VectorStyler; which allows to create gradients along a path
                  and allows them to be applied to the design's paths using the "Style Picker" group function.
                    Another Variation of it
                      monsterfox @Subpath
                      @Subpath These graphics look quite unique. I’m curious: can VectorStyler create them at the moment?
                        Subpath @monsterfox
                        @monsterfox
                        I think some of the Designs would be possible in Vectorstyler
                        all you need is a straight Line, rotate it a bit and copy and repeate it
                        But i think it is way easier to do it in Nodebox because one would have more Options
                        when you could set single Points and connect those Points with a Line i dont think
                        that Vectorstyler could set single points.
                        To set single points and connect them its very easy in Nodebox. (Nodebox is free, PC and Mac
                        in the mean time there is also a Version for Silicon based Macs )
                        All you need is a Path and a Point Node which say how much Points a Path should have.
                        This way you could create all kind of Point Patterns and connect them.
                        Here how the base Structure is made
                        and here the whole Design
