    Bug Report & Improvement Request: Space/Dash Menu Mapping and ZENKAKU Space
    21 Posts 2 Posters 153 Views 2 Watching
      VectorStyler @861475_VctSt
      @861475_VctSt
      And one more thing:
      Create a vstyler file with the following:
      • a shape text with some text and the "Half-width space (U+0020)" as VectorStyler inputs it
      • other shape text with some text and the "ZENKAKU space (U+3000)" as VectorStyler inputs it
      and send me the file.
      I want to check what action character codes are input
      861475_VctSt8 2 Replies Last reply Reply Quote 0
      • 861475_VctSt8 Offline
        861475_VctSt @VectorStyler
        This post is deleted!
          @VectorStyler said in Bug Report & Improvement Request: Space/Dash Menu Mapping and ZENKAKU Space:
          I have sent it via email.
          However, I do not think this is the result you were hoping for. After all, this is precisely the heart of the problem.
          I attempted the input using a total of four different methods, including this one.
          I hope at least one of them proves helpful to you.
            @861475_VctSt Got it!
              ver. 1.3.022–1.3.023: Handled via email correspondence.
              ver. 1.3.024
              Follow-up report regarding two issues.
              I will refrain from offering my own analysis of the causes (as I am not a programmer).
              Note: The character code identification is based on the VS glyph palette.
              1. Localization: Translation error
              1. Space character input
                u3000 (ZENKAKU Space; Ideographic-Space): Input result is U+2003.
                u0020 (HANKAKU-Space; Space): Input result displays as u100001 (Supplementary Private Use Area-B).
                @861475_VctSt I will try to thix these.
                Can you send me the translation errors as text, not image? Thanks!
                  I’m prone to making mistakes myself, so I’ll double-check everything and send it to you later.
                    Ver. 1.3.027
                    In my previous posts, I reported multiple issues together that should ideally be addressed separately. To avoid confusion, please let me organize the current situation.
                    The two issues I raised are as follows:
                    A) Text > Insert Character: Japanese localization (translation) errors
                    B) Spaces during Japanese (Kana-Kanji conversion) input: Issues with half-width and full-width space input
                    [Current Status]
                    A) Resolved (ver. 1.3.026) - Thank you for fixing this.
                    B) Unresolved (ver. 1.3.027)
                    Additionally, regarding the character insertion from the menu (A), a new issue, "Issue A-1", has been found. The details are as follows:
                    [Details of Issue B (Unresolved)]
                    Current Bug:
                    1. When typing a half-width space on the keyboard, it does not become half-width. When checking the Glyph palette, it shows an abnormal code of "U+100001".
                    2. When typing a full-width space on the keyboard, it visually appears as full-width, but the Glyph palette shows it as "U+2003 (EM Space)".
                    Expected Result:
                    1. Half-width space = Space (U+0020)
                    2. Full-width space = Ideographic Space (U+3000)
                    [Details of Issue A-1 (New)]
                    When inserting a space from the menu, the visual result on the screen is fine, but checking it in the VS Glyph palette reveals that the internal code seems incorrect.
                    Current Bug:
                    • En Space: Displayed as "U+0000"
                    • Em Space (Kuwata): Displayed as "U+0000"
                    Expected Result:
                    • En Space = U+2000
                    • Em Space (Kuwata) = U+2001
                    [Proposal for Future Development]
                    Since I am not a programmer, I can only report the results I see on the screen. I have provided materials so far, but I assume that providing information solely from a user level might not be enough to reach a fundamental solution.
                    If digging deeper into the specific requirements of the Japanese environment risks causing regressions or degrading other features, and becomes an obstacle to the overall development of VectorStyler, I believe it is a reasonable option to put this complex issue (such as the U+3000 problem) on hold for now and treat it as a "Known Issue".
                    However, even in that case, there is one top priority that I would like you to fix at the very least.
                    That is problem [Issue B - 1].
                    If we can just correctly input a standard "half-width space (U+0020)" from the keyboard, we will be able to proceed with our work for the time being.
                    This is a proposal meant to avoid hindering the overall development progress of VectorStyler. Please consider this in light of the current situation.
                      @861475_VctSt Added some diagnostic for analyzing these issues.
                      More info in email.
                        I have sent the results.
                        Best regards.
