    How Can I Set the Default Brush Stroke?
    10 Posts 4 Posters 57 Views 3 Watching
      I’ve noticed this minor issue for quite a while, so it isn’t specific to a recent build.
      When I switch to the Brush Tool, it frequently selects the second brush in the list instead of the top one. Is there a setting that lets me choose which brush stroke is selected by default?
      There’s nothing wrong with the second brush. I just don’t use that style very often.
      4906a0ed-f0c7-4526-8f86-3d5af8051b9e-CleanShot 2026-08-27 at 14.02.08@2x.png
      L VectorStylerV S 3 Replies Last reply Reply Quote 1
      • L Offline
        Li Xiao @Boldline
        @Boldline Open the Brush Presets panel and drag and drop the brush you want into the first row.
          @Boldline There is not default in this sense. The brush used in drawing should be the brush that was on the last selected object.
            Subpath @Boldline
            In this tutorial, I have shown a very fast and somewhat unusual way
            for selecting a brush. It requires some preparation.
            If you work with solid strokes you need to use the Pencil.
            Here the Link to the part of the Tutorial.
            https://www.vectorstyler.com/forum/topic/5850/some-basics-regarding-the-creation-and-use-of-artistic-brushes-as-well-as-a-fast-way-for-selecting-such-a-brush./3
              @VectorStyler hmmm. From my experiences, VS always favors the second brush in the list.
              When I open a new VS file and then open the brushes panel, it's always set to the second brush down:
              It often will use that brush even if I've already selected the top simple one. I will try to get that in a video.
              In the meantime, in trying to show that issue, I have a different one where if I switch brushes after making a shape, the next one I create reverts back to the previous brush. Here is a video of that
                @Boldline said in How Can I Set the Default Brush Stroke?:
                Yes, this is the case. Different opened documents have different current brushes.
                But inside one document, if you select a brush it should stay (for that document) the default.
                  @VectorStyler said in How Can I Set the Default Brush Stroke?:
                  @VectorStyler ok. but in a case like this video, why does it switch back to the previous brush?
                    Because if you select the first item that cannot be used as a default by the brush, since it is a solid stroke.
                    The brush tool will apply a brush, even if the default is just a solid stroke.
                    You need to use the Pencil tool to draw with solid strokes
                      Boldline @Subpath
                      @Subpath said in How Can I Set the Default Brush Stroke?:
                      ok - thank you! Somehow this was not computing in my head.
                        Subpath @Boldline
                        How about using a simple rectangle of the appropriate height?
                        And creating an Artistic Brush Preset from it?
                        That way, this version would be the second brush.
                        I have no idea right now what the difference to the "Pencil" version would be—at least I don't see one.
