Regression when increasing or decreasing stroke width
There is a noticeable lag when increasing/decreasing stroke width using the bracket method (long press).
In the earlier versions of VS 1.3 the transformation would happen in real-time. -
@VectorStyler said in Regression when increasing or decreasing stroke width:
Is the lag only in refresh?
I will try to improve this
This is happening whenever I attempt to make a stroke wider or thinner. Even if you refresh, there's no difference.
