GPU view problem with Nvidia
@Mohammadreza Should be no need to install a separate CUDA driver.
It seems that for some reason VectorStyler cannot use this CUDA version. I will test it and find a solution for this. -
@VectorStyler Thanks!
update about v 1.3.019
the problem still exist but now everything is black!!
@Mohammadreza said in GPU view problem with Nvidia:
is the gradient rendering with CUDA working (with CPU view mode, and CUDA compute)?
@VectorStyler yes and working with gradinet and moving a gradinet object is much smoother than previous verison
@Mohammadreza Save a file VectorStyler with the GPU view mode enabled and send it to my email: csraba at vectorstyler.com
@VectorStyler done!
after updating to 1.3.020 the problem still exists
and its also crash with opencl when switching to GPU mode
@Mohammadreza Yes this was not solved yet, as I could not replicate it.
I will test the opencl crash
