    Redrawing screen hide toolbars and then show them again
    16 Posts 3 Posters 114 Views 3 Watching
    • debraspicherD Offline
      debraspicher @marce
      @marce I've seen the grid flickering, but have not seen the interface flickering like that.
      32GB RAM @ 6000MHz
        VectorStyler @marce
        @marce This looks problematic, not sure what could cause this.
        Did this happen while holding the mouse and dragging in the color wheel?
        Also: is the Windows display scaled in Windows Settings?
          marce @VectorStyler
          @VectorStyler said in Redrawing screen hide toolbars and then show them again:
          Hi. No scaling. I have been trying to found when it happens, but im unable. It just happens randomly. I deactivated the multiple monitors, i changed the performance from software to gpu, but it randomly continue doing this.
          My setup is quite regular. Meanwhile writing here, VS made this issue. I was doing nothing with it, it was just open.
          I see some other strange things related to the screen. One of them is that pointers contour looks pixelated as you can see in this screenshot:
          Memory 48gb ddr4
          NVMe CT100p 1TB
            VectorStyler @marce
            @marce Did this occur in previous versions?
              marce @VectorStyler
              @VectorStyler I dont remember to saw that behavior, i try to report inmediately when i see something..
              Can an older version be installed along with the current to test or this is not possible?
              Memory 48gb ddr4
              NVMe CT100p 1TB
                VectorStyler @marce
                @marce You can install an older version but first you have to remove the current one.
                Another thing to try: uninstall VS and remove all files from "Program Files \ NumericPath"
                and let me know if after the Windows uninstall, something is left in that folder
                on Windows the MSI installer can create problems when updating (by not updating some files)
                  marce @VectorStyler
                  @VectorStyler The uninstaller deleted the Numeric Path folder, nothing left behind.
                  I installed VS 1.2.078. That is the one i had in my downloads folder.
                  I started working on it. Long run, but after a while, it did something similar. Not so long as it happened in 1.3, but it did something similar. Menus drawing appear faster in 1.2 than in 1.3.
                  So far, i dont know what can be the issue. My Graphics Card is an Standard nVidia. The exact model is Geforce GTX 970 with 4gb or ram.
                  I dont have issues in the rest of the system with the display, i use several other programs for design, and appear related to VS. But im not able to root the cause. If i leave open 1.2 without doing nothing, it flickers as 1.3.
                  Memory 48gb ddr4
                  NVMe CT100p 1TB
                    VectorStyler @marce
                    @marce I will try to find out what can cause this
                      marce @VectorStyler
                      @VectorStyler In 017 it also does the same.
                      Memory 48gb ddr4
                      NVMe CT100p 1TB
                      VectorStylerV M 2 Replies Last reply Reply Quote 1
                        VectorStyler @marce
                        @marce Could not replicate this issue yet.
                          marce @marce
                          For some reason 018 does it but not so often. I was believen it was fixed, but at last, it did it. I know you couldnt find the casus still, but anyway i believed was good to know.
                          Memory 48gb ddr4
                          NVMe CT100p 1TB
                            marce @marce
                            So annoying, no fixed by any of the updates. My windows machine, pretty standard, dont like VectorStyler.
                            Memory 48gb ddr4
                            NVMe CT100p 1TB
                              VectorStyler @marce
                              @marce said in Redrawing screen hide toolbars and then show them again:
                              The problem is that I cannot replicate this.
                              Did you try with all default settings / workspace?
                                marce @VectorStyler
                                @VectorStyler Yes, i reset the settings, restarted it. The same thing. It flickers, often. I dont know if there any other thing i can do to inform the problem, some kind of log vstyler saves.
                                Memory 48gb ddr4
                                NVMe CT100p 1TB
                                  VectorStyler @marce
                                  There is no log saved.
                                  Is this on Windows 11?
