@VectorStyler Enable the Snap to Points function: when the cursor hovers over a node, there is a change, so we can notice the difference. However, if you select an object and move it to a node, the cursor shows no response at all. I use this operation frequently and always think the object has snapped to the point, but when zooming in, there is still a slight distance gap. Perhaps the Snap to Points function does not fully support this operation yet. Hope this issue can be resolved.
@VectorStyler The Actions panel does not yet support file export operations.
I will add this
https://youtu.be/mk1Jyl9ENVA?feature=shared
In VectorStyler, when drawing the first anchor point with the Pen Tool, it’s not possible to generate two control handles. This results in a sharp corner when closing the path at the end. However, FreeHand allows generating two control handles, enabling a smooth transition when closing the path. Additionally, in FreeHand, while dragging a control handle and the mouse is still in the control state, holding the Ctrl key lets you move the anchor point for more precise adjustments. Currently, this doesn’t seem to work in VectorStyler. These two aspects need optimization.
In VectorStyler, when drawing the first anchor point with the Pen Tool, it’s not possible to generate two control handles. This results in a sharp corner when closing the path at the end. However, FreeHand allows generating two control handles, enabling a smooth transition when closing the path. Additionally, in FreeHand, while dragging a control handle and the mouse is still in the control state, holding the Ctrl key lets you move the anchor point for more precise adjustments. Currently, this doesn’t seem to work in VectorStyler. These two aspects need optimization.I will open a bug on this, for later.
@VectorStyler For the Along Path option in the Repeater, two functions are needed: 1. Distribute evenly along the entire path. 2. Distribute evenly and stretch to fit the entire path. This feature can be referenced from Inkscape.
@VectorStyler Please add the Remove Halftone function from the halftone hidden menu to the panel as a button, just like the Repeater.
@monsterfox I will add these
@VectorStyler I hope to add a lock function to the Recent Operations panel, which should have the following two features:
1. Locked operation records will not be overwritten or updated by subsequent operations and will be retained permanently.
2. Locked records cannot be deleted directly; they need to be manually unlocked before deletion.In my daily workflow, I often need to save a set of recent operations. However, if I don’t use them for a short period, they will be replaced by new operations. If I need to reuse the previous set of operations later, I have to perform all those steps again, which is rather cumbersome.
If this lock function is implemented, I can lock the required operation set to prevent it from being lost. When I need to use it, I can just delete all existing records—since the locked operation set won’t be deleted, I can use it directly, which will greatly improve my workflow efficiency. I sincerely hope this feature can be added.
@VectorStyler I hope that when an object is selected first, and then a shape from my custom styles is chosen, the selected object can be replaced with the styled shape at its original coordinate position.
If a node is selected instead of an object, I also wish that the styled shape can replace the node at the node’s current coordinate position. This would enable much more precise shape replacement operations.
It would be absolutely perfect if this feature could be integrated into the shape selection tool, style panel, and the shape selection function in the menu bar.
