Oil and Watercolor for VS Designs with Rebelle
  • @Boldline
    Here a Workaround for filling a Path
    I think the best way at the Moment is to create
    a Stencil from it as i show it in the video
    Here the Video
  • @Boldline
    Here is a slightly better way to fill a Shape of a Path
    using a Stencil.
    Here the Video
  • Short Update on SVG-Paths in Rebelle 7
    Since the latest 7.1 update
    You can use multiple Paths and Stencils
    at the same time now. Also both together.
    Creating a Selection from a Path is now possible.
    Filling a Path is now also possible, in this way:
    Place a Path on the canvas
    create a Selection from the Path
    and fill the Selection.
    Stencils can be created from a Selection.
    Also a Selection from a Stencil.
    All in all, that new improvements make working
    with Paths and Stencils in Rebelle more useful.
  • Rebelle version 8 is available in Early Access.
    There is a Standard and a Pro version.
    Only the Pro version now has Bristle Brushes and an improved Impasto,
    which can be used to create interesting 3D effects.
    I came up with the idea of trying out Impasto with stencils.
    Stencils are simply grayscale or black and white PNGs, for
    which you can also use Vectorstyler vector graphic designs.
    Here are two examples:
    Here the Stencil
    Here another try, were made with two stencils
  • Cool, thanks for sharing. I first heard about Rebelle yesterday, and I'm going to see what it can do for me.
  • @Ingolf
    gladly,
    when it comes to using/refining vector graphics created with Vectorstyler,
    Paths and Stencils in Rebelle are particularly the most interesting.
    Rebelle also offers, in my opinion, the best digital watercolor simulation.
    Oil painting is also pretty cool. One should not expect miracles, because
    ultimately, this is a digital simulation and not the real thing.
    Paths are vector graphics in SVG format and can be quite wild. A brush in
    Rebelle still follows each individual path like a ruler. This also applies
    to the eraser, liquifier, smudge, and water brush.
    Stencils are simple grayscale or black-and-white raster graphics in PNG
    format. Stencils are like Masks you could brush over it hide the stencil
    and you have your design.
    Paths and Stencils can be converted into Selections.
    Currently Selections could only converted back in Stencils.
    There is no Text Tool in Rebelle, but you could create a Stencil
    from your Vectorstyler Text and use this in Rebelle.
    Here how wild Paths could be, a brush will follow every
    single Path. This could mean a lot of handy work.
    Here i made some test using the Watercolor brush along a Path
    and one using the Liquify brush.
    Here my Stencil and Path Folder
  • This post is deleted!
  • @VectorStyler
    curious post here, see above would guess it is spam
    @Subpath Clearly a spam, removed.
